So a “Wheeler and dealer” friend dumped a present with me, several POUNDS of stag antler bits. These appear to be from a knife making shop, since sifting through I’ve found some partial traditional scale pieces. Most of the pieces are pretty small cutoffs.
I have a couple of ideas how to use these, but have never worked with stag before. Any pitfalls or newbie mistakes to avoid?
Natural material crafting, input needed
Re: Natural material crafting, input needed
Don’t know a lot about crafting deer or elk antlers, however a couple of things I can tell you is... if you are using power tools go slow because you can burn it like wood; also do it outside because it smells like burnt hair but much worse.Pickmansmodel82 wrote: ↑Wed Jul 15, 2020 5:55 pmSo a “Wheeler and dealer” friend dumped a present with me, several POUNDS of stag antler bits. These appear to be from a knife making shop, since sifting through I’ve found some partial traditional scale pieces. Most of the pieces are pretty small cutoffs.
1 Byrd and 30 “others”
