I am new to this, I confess, and want to learn more about knife uses other than cutting things.
Mind sharing what type of fire starters, methods, are you using?
Accutron wrote: ↑Thu Mar 05, 2020 2:44 pmStriking a ferro rod with the edge ruins the edge. In an emergency, if you don't have a knife with a 90 degree spine, the standard method is to reserve a small sacrificial section of the blade near the ricasso for ferro striking. I've also seen people strike a ferro rod with their spydie hole, although effectiveness will vary depending on the hole's edge sharpness.
I just keep a T15 tool bit with my ferro rod. It has multiple sharp 90 degree edges at 67HRC.
I prefer Bayite brand ferro rods. They have 5" and 6" versions, and are drilled through one end for a lanyard. They throw plenty of hot sparks and the price is good.
I've been known to do a bit of strenuous backpacking on occasion. A reliable fire starter is pretty important. The most sensible fire starter? A Bic lighter and a spare. A couple bucks and you're set.legOFwhat? wrote: ↑Thu Mar 05, 2020 1:03 pmMind sharing what type of fire starters, methods, are you using?
Just recently (December) received the hexa and it's quite nice, the multi-tool that comes with it is well thought out and very useful. It's funny you mention the Mora and the überleben as I got them both to put in my backpack, and the 1st thing I did with the Mora was strike the spine across the Hexa and realized the radius wouldn't cut enough to send sparks. Few seconds with a die grinder to a 3 inch area near the handle and it works fantastic.Mike Blue wrote: überleben Hexå Fire Starter or UST Blastmatch are both excellent for the price point. They will work rain or shine IF your tinder is of the right stuff and you know how to build a fire from small stuff upward. You can make or find your own tinder. Neither of these tools require you to mod your knife. Practicing these fire starting skills are a must. Learning to use them when you really need them puts you behind the curve.
I'd recommend taking a view of the most basic mods done to a simple Mora knife and sheath. One of the first items is to rough up the spine of the blade. A polished surface will not make sparks. A Mora is inexpensive and will serve a lifetime and Mora mods will not scratch up your Spydie. If what you saw were people using the edge of the knife to make sparks, I really wonder who taught them. They probably think a knife is a prybar too.
The best characteristic of my grandsons are they are pyromaniacs like me. Much to my daughter's dismay. Everytime I visit they want me to show them how to spark light a fire again. Mostly it's walking the dog and looking in the Canadian woods for potential tinder. They are getting good at it.
The Jute string sounds like a great idea and I'll have to give it a try, plus you'd have twining to use as well. Since I hated getting pine sap on my hands the beeswax sounds much better for a candle...maybe I just need to butch upBloke wrote: I’m a pyromaniac, no doubt and in the mid ‘80’s it likely saved a mate’s and my life when we got lost on a winter hunting trip
I never go bush here without a ferrocerium rod and I don’t use a knife, edge or spine to strike them as a general rule. You also don’t need to pay good money for ferro rods as I’ve found no difference whatsoever between the you beauty flash rods with antler handles etc. and flimsy strikers that cost $30 plus and the plain Chinesey’s you buy from eBay for $1.
I have all sorts but my personal favourite is a 3/8” diameter x 4” long ferro rod and my favourite striker is a 1/2” High Speed Steel, lathe parting off tool, again bought off eBay for a few bucks. The last one I bought was 8” long so I cut it in half with a 1mm cutting disc in a 5” angle grinder.
As far as tinder goes we have plenty of Paper Bark here which flashes easily with a single spark and even if it’s raining you can find a dry layer in thicker bits. A ball of Jute string for $3 gives you more tinder than you can poke a stick at. A 6” length fluffed up makes excellent tinder too that also flashes with a single spark. Sometimes I’ll plait it about 1-1/2” long and dip an 1” in molten beeswax and fluff the rest which make great little candles that burn very well and for quite a while.
Edited to add: With utmost respect, in my personal experience a Bic lighter is the very last thing I’d rely on to light a fire outdoors. Particularly in a survival situation. I reckon they’re as handy as a hip pocket on a T shirt and would much rather a box of matches.
sal wrote:Knife afi's are pretty far out, steel junky's more so, but "edge junky's" are just nuts.![]()
Everyone of my Bics (multiple) has a proper size O-ring around the body and fitted under the lip of the igniter lever. No room for the lever to get depressed and expel fuel. The zip tie seems a one time use object. A hard box is a great recommendation. Other little necessary bits like jute cord w/paraffin, fit in there too.
That is pretty accurate!!! I have been a bit of a pyromaniac all my life. Luckily I burn about 5 cords of wood each year and that scratches the itch.
Users browsing this forum: benben, Google [Bot] and 9 guests
