So, I am seriously impressed with the M*Carbo trigger spring!
Imo, if you have a rifle that has no creep to begin with, then the M*Carbo trigger spring is so nice. At $12 it will more than cut your trigger pull weight in half. I just added one to my FN SPR 300 wsm. I picked a heckuva time to loose my trigger gauge, but I would guess it may be as light as 1.5 pounds. Just really hard to say without a gauge.
M*Carbo
Re: M*Carbo
So, I finally found my trigger pull weight gauge.
And, after taking both nuts off and replacing the factory spring with the M*Carbo trigger spring, the trigger pull weight is a CONSISTENT 1.5 pounds. I will also say, that this is the best rifle trigger I've ever felt. A lot to be said of the older Winchester model 70 triggers imo.
