shunsui wrote: ↑Tue Oct 22, 2019 4:13 pm
4Runners are the poor man's Land Cruiser, made in Japan at the same plant.
These things can run forever if you change the oil.
Good deals on 2019 models WITHOUT all the safety radar tech. 2020 models HAVE the safety tech and Apple Car Play, so the dealers probably are having a hard time selling the 2019's. Costco has an auto buying program that will save you some money and the dealer's have $1500 back until Nov 4 IIRC. (Might increase in November)
If you're not a fan of the car's computer playing with your brakes and steering, it might be a good choice. (Software always works perfectly, right ?)
Port injection engine that doesn't build up crud on your valves like direct injection... just an added bonus.
A Savage review:
https://youtu.be/x2d2ZO19AWw
On my mom's 2019 Camry, I played around with the computer and used the car for several hundred miles. There are 3 settings for how much control the computer has for steering the car and braking. The system goes all the way from totally off to making small adjustments...it tries to move you "back in to the lane" if you cross a solid line in the road.
I absolutely do not recommend the computer system, and more than once had the system trying to "fix" the driving situation by grabbing control and steering the car. It can be overridden, by steering the car. The problem is that the computer does not know where the lane is, or which lane you are trying to merge in too, OR stay out of. DO NOT USE THE COMPUTER TO STEER THE CAR.
Other than that the car seems like a very nice car. It's a 4cyl, so it is kind of torquey at the top end. It is more powerful than I thought. It goes from mild mannered to full blast when it gets on the cam.
Has 5,500 miles on it, and averages 26 to 27mpg overall, but you can get in to the 40's if you work on it.
