Torx set
- Naperville
Re: Torx set
I have the following in my notes and will probably get the Wiha. Drivers for knives
Wiha (L T6-T20 set) or Snap-On
6 - 10, 12 and 15
WIHA: System 4 Slotted/Phillips/Hex Metric/Torx® Micro Bit 27 Piece Set with ESD Safe Precision Handle
https://www.wihatools.com/system-4-slot ... ion-handle
6 - 10, 12 and 15
- Mad Mac
- Location: Northern Far West Deep East Texas in the Dirty South
Re: Torx set
Five years ago I bought this set on eBay. Here it is on Amazon for $18.
https://www.amazon.com/17pc-Precision-S ... =hi&sr=1-9
One thing I like about it is that it fits in one of the pockets on my Spyderpac knife roll.
In addition to torx it has many other additional bits that may be needed.
1990: Endura SE, Delica PE, Mariner, Police. 2014: ClipiTool Bottle Opener. 2015: Kitchen Knife PE, Tenacious CE, Stretch PE, Moran Drop Point, Kiwi, 2 Byrd Cara Caras, Schempp Bowie, Native 5 Forum Knife, Police SE, Tenacious SE, 4" Paring Knife, 2" Paring Knife, Terzuola Starmate. 2016: The Spyderco Story, Terzuola The Tactical Folding Knife, USN Ladybug H-1 Hawkbill SE, Black BaliYo, Yellow H-1 Salt Dragonfly 2 SE, Hennicke Ulize, Pink Native 5 PE, Renegade C23PS and C23P, Gayle Bradley 2, Terzuola Double Bevel, Gayle Bradley Air, Cricket Blue Nishjin, Centofante Memory, K2, 2 Large Lum Pink, Carey Rubicon. 2017: Dialex Battlestation, Orange Southard Positron, Gray Baliyo, Native 5 CE, Tenacious CE. 2018: Schempp EuroEdge, Eric Glesser ClipiTool Standard. 2019 Calendar Contest Reinhold Rhino CF PLN. 2022: Byrd Robin 2 Wharncliffe, Byrd Cara Cara 2 Rescue Orange, Janich Yojimbo 2 CruWear.
Motorcycle adventures in a past life.
Re: Torx set
This is the one I have. I use it with a ratchet driver with a big ball-shaped handle that I've had since I was a kid.
https://www.amazon.com/Wiha-79242-Piece ... 156&sr=8-8
Re: Torx set
Wiha are one of the gold standards but I use a much cheaper Husky set and have only stripped one screw with them and it is loaded with thread locker.
I don't think this exact model is made anymore, they've tweaked the handle shape but they still sell a similar setup.
https://www.homedepot.com/p/Husky-8-in- ... /100074336
If you wanna spend the cash definitely go with Wiha though. This set was like $6 and has worked great for me.
Re: Torx set
what about the Wiha 75093 16 Piece System 4 ESD Slotted, Phillips and Torx Micro Bit Set
Re: Torx set
I use only Wiha t6, t8, t10. Bought individually off Amazon.
Re: Torx set
Ok what torx size works with manix 2
Re: Torx set
^ t6, t8, t10 should do the trick.
I will echo others here.. Wiha are probably the best I've used. I've been really impressed with Bondhus too.
Rick H.
Re: Torx set
I actually just use the cheapo $5 hypertech (hypertough?) set from Walmart. Works fine.
Re: Torx set
next question: Is it better it is a magnetic set? Also which wiha should I get the 75985 or the 75093
Re: Torx set
ever herd of xiaomi mijia wiha 24 in 1 screwdriver kit i just got it off of amazon for $35
just wonder if you ever herd of it and would it be good for adjusting the pivot screw, also
it does have the t5 , 6,8 and 10 sizes also the bits are magnetic
Re: Torx set
Bought this recently based on recommendations from members of this forum. Love it. For knives as well as electronics, jewelry, fishing reels, etc...
