Page 1 of 1
Self-coating steel blades
Posted: Sat Jun 02, 2018 10:34 pm
by AGMartinez
Hi, I would like to black coat a Maxamet blade. Sand, candle wax the blade edge and trim with compass razor (or coat it all and resharpen it), one coat Rustoleum High Heat primer, one+ coat Rustoleum High Heat black, and one+ clear coat of acrylic. Is this cray cray? I've only spray painted or corrosion-resistant coated regular tools, quick and dirty. Has anyone used Valspar brand?
Re: Self-coating steel blades
Posted: Mon Jun 04, 2018 8:35 am
by bearfacedkiller
Yeah, crazy. Even the best spray paint is not very durable and will look terrible in no time.
Look into duracoat or ceracoat.
Posted: Sun Jun 10, 2018 4:30 pm
by Studey
What BFK said. Cerakoting a blade will likely run $35-$45 or so, and by the time you buy three good cans of spray paint, you’re close enough in cost that you might as well do it right.
Posted: Sun Jun 10, 2018 5:40 pm
by Evil D
Recipe for disaster. I wouldn't even trust bake on automotive header paint on a knife blade.
I'm not a big fan of Cerakote either. It isn't as good as a high quality factory applied DLC coating and even that will scratch.
Posted: Sat Jun 16, 2018 8:12 pm
by Stuart Ackerman
Kalgard Gunkote...food safe...
Posted: Sun Jun 17, 2018 7:36 am
by Knife Knut
Posted: Sun Jun 17, 2018 12:31 pm
by Stuart Ackerman
Posted: Thu Jun 21, 2018 11:01 pm
by Frozenspyder
Cerakote would be much thinner than 3+ coats of paint too. Unless the knife has loose tolerances in the pivot area, I could see that potentially causing problems.
