Hey guys,
here are some of my latest regrinds...
A Fallkniven PXL Workhorse and a Bark River Woodland Special. 60, 80 and 120 grit ceramic belt, 400 grit buffing belt.
Hope you like it :)
BR Oliver
My latest regrinds
- _centurio_
- Surfingringo
Re: My latest regrinds
nice work!
- SpyderNut
Well done. You're getting pretty good at that. :)
Very nice. How thin behind the edge?
- _centurio_
Thank you very much!
About 12 and 15 thousands of an inch thick behind the edge.
NICE._centurio_ wrote:Thank you very much!
Nice work Centurio!_centurio_ wrote:Hey guys,
BR Oliver
I was inspired by all the regrinds by you and others around the forums. Picked up a Harbor Freight 1×30 and some ceramic belts from Supergrit recently. Did my first power grinding today with a drip line setup for a wet grind.
Really happy with how my Enlan turned out. Wimped out and wanted some practice before I go after any Spydies :)
Didn't completely get rid of the hollow, but I was mindful of your thread about going too thin.
:spyder:
- _centurio_
Thanks, nice to hear :)Nate wrote:Nice work Centurio!_centurio_ wrote:Hey guys,
BR Oliver
That's the problem with regrinding hollow grind knives (on a flat platen or convex) that you get too thin at the edge. If you get to zero with the whole blade bevel you have to remove a lot of metal when grinding the new edge....
But your regrind looks nice
BR Oliver
Yes, with hindsight I suppose I should have worked the top half to near full height first and then ground the whole blade flat at a lower primary angle. Something to keep in mind for next time. I plan to flatten my older hollow ground UKPK at some point._centurio_ wrote:
:spyder:
