Signature won't who on old threads
Scorpion
Post by Scorpion »
Typo title should be: Signature won't show on old threads
Is it supposed to be this way?
Techno - Paramilitary 2 - Manbug.
SpyderNut
Post by SpyderNut »
Hmm. Your signature should show up, regardless of the age of the post. There is a small check box on the bottom left corner of the "Reply to thread" box. I believe you need to check this box in order to habe your signature show.
:spyder: -Michael
Post by The Deacon »
When you first post, the HTML to retrieve and display your signature is only created if you have a signature and have it enabled. Once a post is made, that HTML will not be added if you decide to add a signature or enable one that had been disabled.
