Stippling FRN?
- Officer Gigglez
- Location: Originally out of Arizona, currently live in Missouri.
Stippling FRN?
Can it be done? My understanding is that FRN is just polymer, which means it can be stippled just like, say, a polymer framed gun. Or am I incorrect?
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
Just like a Glock, I would imagine..
:spyder: C101PBL2, C54GPBN, C154PBK, MGREP, JGGYP, C75P3, C36TIP, C113GPGY, C127GPOR, C85GPBL, C11SBK, C10SBK, C11TR, C10TR, C28S (Wharncliffe mod), C11TIPD, C12GS, FB15P, C110GPBL, C85GP2, C141CFP, FB14P3Z, C123GPBL, C88PYL, KO4PBK, C105BMP
"For we wrestle not against flesh and blood, but against principalities, against powers, against the rulers of the darkness of this world, against spiritual wickedness in high places...Wherefore take unto you the whole armour of God." Ephesians 6:12-13
- Officer Gigglez
Soldering Iron, hot knife. The same way I would do a poly gun. It seems to me that FRN would be different from polymer in some ways, but it is essentially the same. But I don't want to try it and end up ruining my FRN Spydie. But I may have to get a cheap Byrd with FRN and try it out.Evil D wrote:Interesting idea. How would you do it?
-Tasman Salt, PE
-DiAlex Junior
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
Nylon IS a polymer just like every other plastic but the glass fibers may cause problems. However I would just try it on a Byrd.Officer Gigglez wrote:Soldering Iron, hot knife. The same way I would do a poly gun. It seems to me that FRN would be different from polymer in some ways, but it is essentially the same. But I don't want to try it and end up ruining my FRN Spydie. But I may have to get a cheap Byrd with FRN and try it out.
- The Deacon
FRN can definitely be melted. I've seen FRN folders handles with initials/names burned into them with a soldering iron. I'm fairly certain tonydahose has done that to at least one of the knives he uses for work. The only question would be whether it can be softened and deformed as neatly as the polymer used in Glocks.
If you do it post some pics. That is a neat idea.
What color?
What color?
- Officer Gigglez
It'd be black, mainly because if it does work like polymer, it'll burn. Black burns on black polymer doesn't show up, just the shape that is melted.Doc Dan wrote:If you do it post some pics. That is a neat idea.
What color?
-Tasman Salt, PE
-DiAlex Junior
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
That is a very useful mod. for the beloved Native...one that I am sure to employ on my new LW Native 5 whenever they're available :confused:Jazz wrote:Here's an example of what I did. I removed some FRN to make the finger hole more accessible on the Native.
It carved out a bit ragged, but sanded nicely.
Thanks for sharing!!! What implement / tool did you use for the rough shaping?
Also, when you got time put up some more upclose pics of your Native in the closed positon, if you don't mind :o
What is truth? Pontius Pilate
Re: Stippling FRN?
The polymer (plastic) used for Glocks is Nylon also. It may be a slightly different formulation but it is generally similar material to FRN. I don't think the Glock nylon is reinforced with glass fibers though, and I'm pretty sure Glock frames are cast instead of injection molded.
