Almost a decade ago I found this site and discovered better ways to tie my shoes. The Ian Knot is the one I use - faster and less likely to come untied. As often as you tie your shoes it's worth it to learn a more efficient method.
http://www.fieggen.com/shoelace/knots.htm
18 ways to tie your shoes
- dialex
Wow, thanks for the link. Most instructive. Who would have thought that such a common thing like tying shoelaces can be in fact pretty sophisticated?
Not to mention that my son still has problems tying shoelaces, so this is really useful. :)
I've used that a few times to relace my shoes. Right now I've got the spiderweb lacing since it reduces lace length a good bit.
Chris
Chris
- Nick D. Fingerz
Agreed. Wow. I just never gave shoe laces that much thought. I'll also be trying some of the lacing techniques for my boots that have lots of eyelets.dialex wrote:Wow, thanks for the link. Most instructive. Who would have thought that such a common thing like tying shoelaces can be in fact pretty sophisticated?
Thanks for posting, Sequimite!
42 Spyderco fixed blades and counting...
Interesting, but i'm skeptical that my ~25 or so years of tying shoes the same way will ever change. It'd be a hard habit to break. I must say though, the "two loop" version is the easiest way to teach a young child to tie their shoes. I used that one on my son until he was older and could understand and had the dexterity for the other typical way to tie.
- Minibear453
- darkstar29
I bookmarked this. I had no idea there were so many different ways to tie shoes.Sequimite wrote:Almost a decade ago I found this site and discovered better ways to tie my shoes. The Ian Knot is the one I use - faster and less likely to come untied. As often as you tie your shoes it's worth it to learn a more efficient method.
Now, I'm going to wow and amaze family and friends with my new-found skills. :)
I walk away slow tonight,
and cut through the air
with a curse, like a knife.
+1DCDesigns wrote:I find some of those needlessly complicated. You want to get them off at some point right? lol. I dont think I will be altering my bunny ears technique. If I want it more secure, I double knot the loops.
I use the bunny ear version myself. Tying knots can be fun. You need to know several of them though. But for shoes, one technique is really all you need. The Same method I use for tying shoes and sneakers also works great for tying off sweat pants.
"The World is insane, with small pockets of sanity here & there. Not the other way around."
:spyder:-John Cleese- :spyder:
