EDC Flashlight carry
araneae
Postby araneae » Sat May 14, 2011 9:04 am
I have a Streamlight Nano Micro LED on my key chain. Tiny, but effective. If I need something bigger, I'll find it in the house or car.
-Nick
Just got: SpyOpera, Siren
mkd
Postby mkd » Sun May 15, 2011 9:15 am
my favorite is a zebra light single aa h51 model. i also like the fenix e21 and the fenix ld20. the zebra light has 3 ranges with 2 settings in each range that are programable.i bought it for use as a headlamp when i snowblow the driveway but also use it for hunting when i want a light for finding trail markers and setting the blind up in the dark. it comes with the head band and 2 light holders plus a pocket clip that is detachable.
Piet.S
Postby Piet.S » Sun May 15, 2011 9:39 am
Fenix stainless LDO1.
Because it is so small that I have it allways with me.
Just like with knives, the best one is the one in your pocket when you need it.
All your knifelinks, http://www.knifelinksportal.com
Mr Blonde
Postby Mr Blonde » Sun May 15, 2011 10:24 am
I have 1 x AAA Titanium Innovations Illuminati on my Keyring that's proven to be an excellent little flashlight. For a 'real' EDC flashlight I prefer something that uses only 1 CR123 battery. Surefire has proven to be very disappointing for this flashlightgeek this year (no interesting new models in the 1 x CR123 format), so I've switched over to the excellent (so far) Nitecore Infiled.
Last website update: 12-31-2020 - Twitter - Instagram
ChrisM
Postby ChrisM » Mon May 16, 2011 12:08 am
4sevens mini cr2 dropped in either front pocket, depending on which hand I was holding it in last.
phillipsted
Postby phillipsted » Mon May 16, 2011 9:59 am
I have two for EDC. The first is a Quark Mini 123 which I keep in my front pocket. The second is my Quark 123 tactical, which I keep in its sheath in my briefcase.
TedP
Worry less - Breathe more...
Spydie Fanatic #185
Donut
Postby Donut » Mon May 16, 2011 11:02 am
Water_Gremlin wrote:I prefer the larger more capable flashlights, my current EDC light is a 4-7's Quark CR123x2 with an 18650 body. Great light but the 18650 body fit an finish is poor which leads to a poor battery connection and a quite often a flickering light.
Before I carried a Preon 2. Great light but I wanted something brighter.
A problem that might also be causing what you are seeing is that one 18650 over the discharge of the battery will most of the time be out of regulation. To run 1x18650 you should use a single cell head and it will operate in regulation over the entire discharge.
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
numb
Postby numb » Mon May 16, 2011 2:15 pm
I have a Fenix E01 on my keys and usually a D10 R2 with an AW 14500 in my shirt/ jacket. The E01 is **** near unbreakable, Ive accidently run it in the washingmachine several times and dropped it from 9m height once and its still working. :D
/N
KBR
Postby KBR » Mon May 16, 2011 4:59 pm
I posted earlier that I carried an Arc AAA on my keychain, but I just received this Fenix E01, as a gift from a friend, and it has since replaced the Arc on my keychain. :D :D
Mario
"A man who is "of sound mind" is one who keeps the inner madman under lock and key."--- Paul Valery
Survive, Adapt, and Overcome...
firearmsp
Postby firearmsp » Fri Jun 03, 2011 10:35 am
try some fenix lights. very good for the price and very brith too. there are lot of models i"m sure you would find some for your edc.
Ko se stidi majcinjega mleka taj ce biti rdja dovijeka!
SPYDERCO:
:spyder: Police 2 G-2 SS,Endura 4 VG-10 FRN, Military CamoBlackBlade S30V, Police 3 VG-10 G-10, :spyder:
KERSHAW:
Blackout 1550
COLD STEEL:
Spartan
jossta
Postby jossta » Fri Jun 03, 2011 12:50 pm
I used to edc a Modamag Draco on my keychain. That was pretty much the best light ever. Super tiny, rechargeable, 100 lumens and multiple modes. I just sold it to help pay for my Chinook II though b/c batteries and o-rings are a pain to order and I figured as irresponsible as I am, edcing an $150 custom light is probably not the best idea.
Anyway, pretty sure I'm going to get the Fenix LD01 or LD15 to replace it. A little bigger, but won't kill me to replace. Might also get a glo toob, but the lithium one is the same price as an ld15, so probably not.
I also have a 6px Pro that I carry in my laptop backpack or in the car.
DeathBySnooSnoo
Postby DeathBySnooSnoo » Fri Jun 03, 2011 1:05 pm
I've tried to find an EDC keychain light for ages but nothing seems to fit what I want. Small (duh, keychain light), around 80 lumens, button switch, and around $40. So for now...I have a cheap $5 light that I usually forget to take...ha ha
On the hunt for...
STAK
Postby STAK » Fri Jun 03, 2011 3:26 pm
:spyder: I EDC a FENIX-PD20-R5 LFP and a FENIX-LD01-R2 LFCP, also a FENIX-LD01-Q5 attached to my keychain ;) . . . . I also EDC 4SEVENS-QUARK-123^2-R5 LFP or FENIX-LD10-R4 LFP and PREON-1-R5 LFCP :) . . . . FENIX-LD20-R4 and FENIX-PD30-R4 are always attached on my backpack :) . . . . :spyder:
DMgangl
Postby DMgangl » Fri Jun 03, 2011 4:01 pm
I carry my Surefire E1B clipped in my LFP. Ive had the light for a few years now and its my preferred light when not at work. The dual clip is very handy, and the low setting is great for regular tasks.
At work I keep my G2L and a maglite LED in my tool bag.
DM
Smile, it can always get worse
vampyrewolf
Postby vampyrewolf » Fri Jun 03, 2011 4:04 pm
3 that get rotated... Inova x1 in O/ST rig, Inova x5 in nylon sheath, and SF 6P w/ P61 head in SF sheath... they all end up on my left hip just behind the multitool.
Coffee before Conciousness
Samwise
Postby Samwise » Fri Jun 03, 2011 4:18 pm
7777 Quark MiniX 123, around my neck on the OEM lanyard. I keep it under my shirt until I need to use it.
Spydie Count: :spyder::spyder::spyder::spyder::spyder::spyder::spyder:
Vics: Super Tinker, Farmer
TrickyVic
Postby TrickyVic » Fri Jun 03, 2011 4:39 pm
I carry a Preon 1 w/clicky or a Zebralight SC51 clipped to my left front pocket.
bohica1998
Postby bohica1998 » Fri Jun 03, 2011 4:47 pm
It WAS a Surefire Aviator A2, until I won a TK15 (2 x CR123 OR 1 x 18650) in a GAW. Man, this light is awesome!
Many different settings from 'barely there' to 'turbo'. In the turbo setting this thing is like a searchlight (337 Lumens).
My backup is a 4-7's Quark Mini 123 (1 x CR123) on it's OEM lanyard.
58-1/2 :spyder:'s so far...:p
Latest Arrival: C14PBK PE Rescue (Thanx Jeff!)
On the Way: Nada at the moment
Water Bug
Postby Water Bug » Fri Jun 03, 2011 7:16 pm
I EDC both a SureFire 6P and a Mini Maglite. Both of these flashlights are carried in custom-made leather holsters and are worn on my belt.
These holsters offer secure carry and easy access as I simply press the flashlights from their bottom ends up out of the holsters.
I'm sure there are people who see me with two flashlights hanging off my belt in leather holsters who think I'm weird or whatever... well, at least I'll be able to find my way out of the dark. :)
Spyderco WTC #1044
telemeister
Postby telemeister » Fri Jun 03, 2011 9:22 pm
I EDC either a SureFire L4 or the E2D defender, both really cool flashlights. Not sure what it is about them, but they are the Spyderco of flashlights for me :) . I also just bought one of their pens, which is awesome (heavy and thick though - which doesn't bother me).
On my helmet, I've got a Petzl MYO RXP
Top :spyder:s : Caly 3, Stretch, Millie, Manix 2, Police, Kopa, Polliwog, Meerkat, Chinook III, and SuperHawk.
[SIGPIC][/SIGPIC] Click the pic to see my :spyder:
Return to “Off-Topic”
Users browsing this forum: No registered users and 6 guests
