Hardware coating
Hardware coating
Dumb question but I’ve never used coated hardware. My salt 2 has it blacked out and after getting the knife really dirty I ran it under the water for a bit to clean when it dried off the pivot was really tight. Is this common?
Quia surrexit Dominus vere, alleluia
Re: Hardware coating
Doesn't look like your question was ever answered. Was is really hot water? That can cause things to expand. Other than that, I have noticed when cleaning out the pivot area occasionally the pivot area will become less smooth to operate. Probably just because it is dry. You could try a few drops of oil and work it in to see if that resolves it. I do not think the coated hardware has anything to do with it.
- cabfrank
I've had that happen too, and it goes against the idea of Salts not needing lube.
I do feel like they break in over time and don't require it as often or ever. But especially at first. Not a salt, but I needed oil on my LW Native 5 when I first broke it in. That thing would get ridiculously tight the first week.
- cabfrank
Agreed, not often at all, but every now and then a drop or two makes a difference.
Dirt, grit, rubbing together creates friction. A drop of oil helps and may flush it out.
