Stretch 2 XL in grey G10 and CruWear steel!
Re: Stretch 2 XL in grey G10 and CruWear steel!
That Manix turned out great!
I've found that the requests in order notes often get ignored, but maybe not with DLT.
- Manixguy@1994
I can’t say enough good things about DLT . They have treated me very well every time I order . Dealer I ordered from for first order suggested by Beau also were fantastic. They reached out with a personal call after getting knife asking if I was happy with the XL , great guys . Dan
- kennethsime
Well, I spoke too soon. I took the knife apart to RIT dye tonight and discovered that I too have contact between the blade and the lanyard tube.
I still have the knife apart, but perhaps an easy fix would be to replace the stepped lanyard tube with a non-stepped lanyard tube? It does appear as if the knife rests equally on the kick of the ricasso and the lanyard tube. I'll go ahead and leave mine out for now.
- kennethsime
With the lanyard tube removed, the blade rests comfortably on the kick of the ricasso.
With not much else to do today, I went looking around the house for a box to slice up. Lucky me, I had a wheelset delivered last week, and was able to cut up the box. The Stretch 2 XL is no slouch - the thin grind slices right through quad-walled cardboard. This knife is definitely a keeper.
Unfortunately, my Lynch clip was either delivered to a neighbor or lost in the mail. May have to order another one. Also, my RIT dye job was unsuccessful - I guess G-10 is harder to dye than FRN and FRCP. I'll have to do some more research before trying again.
- cabfrank
Well, a non-stepped lanyard tube does sound like an easy solution, if you can find the right replacement, and if it would stay put. That sounds like an easy CQI fix for Spyderco as well.
- cabfrank
I suppose a "less-stepped" version would work also, if that makes sense, and if such a thing exists.
- kennethsime
My hope would be that Spyderco would take note of this thread, implement the fix, and perhaps even offer a solution to those of us who write in about it. I know the parts come from Japan, but you'd think they might be able to source a replacement option here in the states.
- kennethsime
Maybe. The clearance is very, very tight.
- steelcity16
Yep, I took mine apart and planned to file the step down on the tube, but I mangled the tube getting it out, so now I am ridin' tubeless. Kind of bothers my OCD that it is not a "stock" knife anymore, but it works, and the old G10 Enduras were tubeless, so there's that.
- steelcity16
Extremely tight. Even if they made the ricasso kick slightly longer to keep the blade off the tube, the tip of the knife would probably be sticking out ever so slightly or dangerously close to it. They would likely need to alter the grinds a bit too to keep the tip buried and/or keep the belly off the tube. It will be interesting to see how they approach this. There is such little margin for error in this model.
- Manixguy@1994
I could not agree more , quite a few people made an investment anticipating a well made knife . I sadly don’t think this flaw should be acceptable. Dankennethsime wrote: ↑Wed Jan 18, 2023 8:44 pmMy hope would be that Spyderco would take note of this thread, implement the fix, and perhaps even offer a solution to those of us who write in about it. I know the parts come from Japan, but you'd think they might be able to source a replacement option here in the states.
- kennethsime
I emailed Spyderco Customer Service about it. Will report back if I hear anything. It's not worth sending the knife in, I don't think, but I sure would love it if they could find a way to take care of us.Manixguy@1994 wrote: ↑Wed Jan 18, 2023 9:14 pmI could not agree more , quite a few people made an investment anticipating a well made knife . I sadly don’t think this flaw should be acceptable. Dankennethsime wrote: ↑Wed Jan 18, 2023 8:44 pmMy hope would be that Spyderco would take note of this thread, implement the fix, and perhaps even offer a solution to those of us who write in about it. I know the parts come from Japan, but you'd think they might be able to source a replacement option here in the states.
I may have an unpopular opinion here, but with the tolerances required for the lanyard tube on this particular model.....
May I humbly suggest removing the lanyard hole like on the Police 4?
Is it necessary? How many of us are using lanyards with this knife? And as I said the tolerances required have obviously caused a problem. Too much kick the tip will stick up above the handle, too little, you're banging the lanyard tube.
- steelcity16
ZrowsN1s wrote: ↑Wed Jan 18, 2023 10:15 pmI may have an unpopular opinion here, but with the tolerances required for the lanyard tube on this particular model.....
Exactly. Probably the best solution here. I honestly wish they would have just left the tube out altogether like on the previous G10 Endura. I'd feel less bad about removing the tube myself. I hate modding knives. I like 'em stock.
- cabfrank
Agreed. While I admire the mods people make to make their knives their own, I prefer stock Spydercos. I especially wouldn't want to mod a knife in this price range.
I also agree that lanyard tubes are probably not necessary in knives this size. I don't use lanyards at all, but I get why some like them for small knives like the Ladybug/Manbug, etc.
The G10 Shaman doesn't have a tube in it either and looks fine. If removing the tube is easy enough without messing up the scales then I would go that route. So far I don't see mine touching, but I will probably pull the scales just to satisfy my OCD.
- steelcity16
Please do, I am interested to see what it looks like on ones where the blade isn't touching. I wonder if the kick is longer or blade is ground a little more near the tip or what.
I suspect you will see the blade resting on the tube though.
- steelcity16
I assume these knives are hand assembled, right? How do you not see that the blade is literally sitting on the tube when assembling? That is what gets me about it. Crazy these passed QC.
steelcity16 wrote: ↑Thu Jan 19, 2023 11:00 amI assume these knives are hand assembled, right? How do you not see that the blade is literally sitting on the tube when assembling? That is what gets me about it. Crazy these passed QC.
A bit mysterious indeed... still a very intriguing knife, and that is coming from an FRN and LW guy...
In Europe though the "cheapest" option I found is € 329 (translates to 356 USD) - not saying the knife ain´t worth it (I am sure it is!) but I personally will rather wait for the hopefully eventually coming FRN K390 version and probably would save some money even if I added a Leaf Jumper or similarly priced model to the order...
I disassembled mine. Not hitting but the clearance between blade and lanyard tube is less than the thickness of a piece of printer paper!
