Milling issue on ripps scales for crucarta pm2
Am I missing something here? I bought a set of ripps burlap micarta scales for the spyderco pm2, I have the cpm cruwear model with the flat micarta scales (crucarta). The scales they sent me are milled out and the liners do not fit into the milled out section, as the liners are the exact same dimension as the outer edge of the scales, not the same dimension as the inside edge of the milling. Because of this the screws for the backspacer are now not long enough and the scales do not sit flush against the liners. Am I doing something wrong here? Are there more than 1 size of liners for the pm2?
Re: Milling issue on ripps scales for crucarta pm2
Dear Briarsmoke:
The Micarta-handled PM2 is the only PM2 with full liners. All other PM2 models have nested liners. Aftermarket scales are typically made for the style with nested liners, so they will not fit on the full-linered version.
Stay safe,
Mike
Stay safe,
Mike
- WilliamMunny
What Mike said... but if you are stuck with the new scales you could always sand down the raised part, that should hopefully, with some luck, fit fine then.Briarsmoke wrote: ↑Mon Sep 26, 2022 1:10 pmAm I missing something here? I bought a set of ripps burlap micarta scales for the spyderco pm2, I have the cpm cruwear model with the flat micarta scales (crucarta). The scales they sent me are milled out and the liners do not fit into the milled out section, as the liners are the exact same dimension as the outer edge of the scales, not the same dimension as the inside edge of the milling. Because of this the screws for the backspacer are now not long enough and the scales do not sit flush against the liners. Am I doing something wrong here? Are there more than 1 size of liners for the pm2?
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
- kennethsime
Mike hit the nail on the head here.
I would recommend against attempting to modify the scales. They're very well made, and cost a pretty penny. Save them for your next PM2, or pass them on to someone else who can use them.
In the meantime, the factory micarta scales are pretty nice!
