Page 1 of 1
Aftermarket scales for Native 5 LW
Posted: Thu Sep 22, 2022 9:24 am
by JRinFL
I just installed some aftermarket scales (Honest Builds - Etsy) on my Native 5 LW Salt. These ones are almost perfect, except for the portion just behind the lock release. They seem to be just a little low in that spot. Also, it only has clip holes + inserts for right side tip up. Otherwise, a very good 3d model from the maker. I'll have to send some constructive criticism so they can tweak their model.
Also note, the inserts are likely not Salt rated, so don't do what I did and convert a Salt model if you really need full corrosion resistance.
Re: Aftermarket scales for Native 5 LW
Posted: Thu Sep 22, 2022 12:54 pm
by Josh Crutchley
JRinFL wrote: ↑Thu Sep 22, 2022 9:24 am
Looks good! I like that they added the ridges to the backspacer area.
Posted: Thu Sep 22, 2022 6:32 pm
by petz462
Josh Crutchley wrote: ↑Thu Sep 22, 2022 12:54 pm
Agree, looking good! And the seller has plenty of color options.
Posted: Thu Sep 22, 2022 7:46 pm
by JRinFL
I should have taken pictures while it was apart. They did a nice job on the model and it needs only a minor tweak.
Posted: Thu Sep 22, 2022 10:07 pm
by infinkc
Wow, nice to see someone finally making scales for the native.
Posted: Fri Sep 23, 2022 12:01 am
by Toucan
I've been thinking about getting some yojimbo scales from that seller. The glittery glow-in-the-dark and the translucent purple look really good.
I don't think I would use 3d printed scales on a liner-less model unless there has been some giant leap in the materials that can be printed.
