Spydie chef clip removed I need a shorter screw
Just received a new Spydiechef. I use the knife without the pocket clip installed. As the screw used to fix the pocket clip is too long when re-installed without the pocket clip, can anyone tell me what is the actual shorter screw size that is installed on the other side. I wrote to Spyderco asking if I could purchase a shorter screw as installed on the other side, NO reply yet!!! Any suggestions where I can buy the correct screw without fear of any corrosion. UK based
