To be clear: I have real experience only with the PM2 (and also extensively with several lightweight Manixes), but could just handle a Shaman once (did not actually ever cut anything with it).
That said:
- Since it sounds a bit as if this would become your
only or at least main EDC knife:
In that case I´d go with the PM2.
As others have said: Lighter, takes up a bit less pocket space, should be slicier, probably has a more useful tip for typical folder EDC use. I like the PM2 ergos too, both behind the choil and choked up.
If you go for two or more Spydie though, and one of those should either be the PM2 or the Shaman: Then I´d take the Shaman (additionally to something like and Endura, Stretch XL, or Manix LW).
Just from holding the Shaman I knew that one day I´ll have to own one. It feels really good with the rounded scales (even better ergos than the PM2), and I think it looks just so cool and "harmonious" - or not just looks but actually iS in my view, cause it combines the rather beefy blade (stock) with a very robust tip. So one could really make use of that in a way overbuilt blade (for a folder) in pretty much all tasks, cause one would not have to worry about the tip snapping.
I´d not carry it to often though, but certainly would love to use it in "harder" tasks.
- For me the ergos of both in really "hard", prolongued use suffer a tiny bit from the comp.lock cutout and the open back construction. Not a big deal though, cause tasks where one can really feel this are not typical EDC folder tasks anyway.
Still: A "Shaman" with a closed back and no comp.lock cutout, but still the contoured handle would be even better for me.
So in a way a backlock or CBBL Shaman...
- One suggestion:
For "just" about $ 50 more than the S30V Shaman costs you could get a S45 VN PM2 AND a Manix 2 LW in BD1N.
Since you obviously like the Manix platform, I bet there`d be a lot of days (in light shorts, iwb...) where you´d appreciate the light weight and easy carry of that model in its FRCP lightweight version (a bit more than half the weight of a Shaman).
And BD1N is such a nice steel! For me it "punches above its weight class". For how extremely easy and fun it is to sharpen even for a not master sharpener like I am, it holds an edge really well.
I even prefer the Manix LW over the G10. It (the LW) is not flimsy at all, and I figure the closed back could make for even slightly better ergos,
Hope you´ll keep us posted about your final decision and how you´ll like whatever model then!!
