UKPK Penknife blade swap
“You just made me have a bowel movement in my britches, Garrett. I ain't gonna never forgive you for this.”
Re: UKPK Penknife blade swap
I know the original used a different spring, and that the original spring was more than a little finicky. I wouldn't try that one myself, but they are your knives, not mine. The HH Exclusive I have no experience with.
- Superfool
Hey bud.
I have done a LOT of blade swaps to different sets of standard and non-standard scales. S30v, CTSBD1, LC200N, BD1 and s110v. Although they all differ slightly over the years, they have all so far been interchangeable.
That is not a solid gold guarantee though.
I hope that is of help.
While I have never
While I have never
David
Always outnumbered; never outgunned.
Proud member of Sal's Troublemaker Class since July 2020
- RadioactiveSpyder
Please see my post about UKPK blade swaps in this thread (I’m too lazy to rewrite it!):
viewtopic.php?t=86111
The ability to do blade swaps depends on the generation(s) of the UKPKs you’re planning to swap. There were a number of design changes between the older G10/Ti/CF models and the newer FRN and Heinnie Haynes red G10 variant. Hope this helps. Cheers, Radioactive
- Stuart Ackerman
Hi Mark
even between the original models, there were slight differences, as I swapped three around, with CF scales that I made.
The leading edge of the lock bar would protude slightly, or with another swap would be lower, just a tad.
There would have been hand finishing of each model, which would account for the differences.
I am guessing that diff gens would be even more of an issue to solve?
You can always switch back if it doesn't work, none of this is one way only.
