Easy. Create a subsidiary called SpydieCut or whatever. Switch all Zcut or kitchen knife production to it. Laser the blade or mark the handle, “SpydieCut by Spyderco”. No more kitchen knife holes needed. Give the company to Sal’s grandkids or whatever. Instant transfer of wealth for the future generation and the kitchen knife line doesn’t need the hole anymore.BornIn1500 wrote: ↑Wed May 18, 2022 6:33 pmHere's a reason. By not including a trademark on basically all models, it can be harder to defend the trademark's status as a legitimate trademark. I'm sure Sal has said that himself. This is not a patent for its function, so how a round hole makes a knife perform is irrelevant. There are plenty of companies that would be quick to start using it if the trademark is lost.
Broken Z-Cut
Re: Broken Z-Cut
- araneae
Re: Broken Z-Cut
If it was done in by Braunschweiger, there was something off and the tiny Spydie hole does not seem like the culprit so much as a bystander.
-Nick
Last in: N5 Magnacut
-Nick
- curlyhairedboy
Re: Broken Z-Cut
I doubt it's the hole that's the issue; eager to hear what Golden thinks once they have it in. I would guess fatigue affecting a defect already present in the steel.
- cabfrank
Re: Broken Z-Cut
How weird that it was Braunschweiger, of all things. There had to be an issue with that particular knife.
Off topic; I love the stuff, and will have to get some now.
Re: Broken Z-Cut
Yep, I've complained about this in the past. They could be thicker stock with a thinner grind to add rigidity and give up nothing in cutting performance.
Re: Broken Z-Cut
Actually I bought them for their flexibility. I use them for fileting around rib bones on smaller fish. Different cuts made when fileting a fish means different tools for the job. So many fishermen expect one blade to do it all and remain hair popping sharp forever. Ain't happening with any steel. Hacking thick rib bones, chopping heads off see to that. I digress. Flexible blades do have their place, tho.
Re: Broken Z-Cut
Yeah, that's my point. A fillet knife is not ideal for general purpose kitchen duty.
- araneae
Re: Broken Z-Cut
I have cut much harder with mine with no issue, something is off (maybe bad heat treat) and it's not likely simply a spidey hole issue.
-Nick
-Nick
Re: Broken Z-Cut
There might be some misunderstanding based on some of the comments. When I say pressed down, I meant like in spreading motion not in a cutting motion. Still only a few degrees of flex before it snapped. A fillet knife would have shrugged it off like it was nothing. My z-cut seemed to be overly hard or maybe BD1n cannot be used in such thin stock. Maybe just a fluke bad heat treat or inclusion in the steel? I have no answer and that is why I’ll send it in for Spyderco to examine.
My other K series Spydercos have been fine for 20 years or so, so I’ve plenty of knives to assist in kitchen duties.
