Slight mod to 20CV Delica Wharncliffe
Soanso McMasters
Post by Soanso McMasters »
Based on my curiosity about reducing the blade length on another knife I experimented with changing the profile of the spine on my 20CV Delica Wharncliffe. I am actually pleased with the results. Pro tip to anyone looking to mod a blade by hand with no power tools, 80 grit sandpaper works much better than an extra coarse DMT stone. I finished up at 180 grit and then used fine white rods to chamfer the spine. I may yet change the profile a bit, but I’ve stuck it in my pocket for now.
ZrowsN1s
Re: Slight mod to 20CV Delica Wharncliffe
Post by ZrowsN1s »
I wonder how my 80 grit diamond stone would work. Looks good!
ykspydiefan
Post by ykspydiefan »
Nice work Soanso,
That is a properly committed modification, really makes it your own.
R100
Post by R100 »
It would be great to see a photo of it closed if you have one.
I like it . A comparison shot would be neat to see. Thank you for sharing. MG2
I like it! I may try that on my Rock Jumper.
Soanso McMasters
R100 wrote:
Tue May 17, 2022 12:42 am
Soanso McMasters
Tue May 17, 2022 2:34 am
Soanso McMasters
Thanks folks! I can still remove some more material to make the effect more dramatic, and at some point I will. I like the new shape quite a bit.
Last edited by Soanso McMasters on Tue May 17, 2022 1:04 pm, edited 1 time in total.
Wandering_About
Post by Wandering_About »
Looks like you did a good job with it, and learned some things in the process.
MNOSD member #0035
Thank you very educational .
Soanso McMasters
ykspydiefan wrote:
Tue May 17, 2022 12:11 am
Nice work Soanso,
Thanks, I appreciate it. I think I spent something like 3 hours on it! It had just been sitting on a stand on a book shelf with my other knives I don’t carry often, but this gave it some new allure for me. It will be seeing some more pocket time now.
Soanso McMasters
Tue May 17, 2022 1:29 pm
No problem. I don’t know why my pictures post sideways, but if you click the picture it is right side up. Makes it easier to see the difference to my eye.
tonijedi
Post by tonijedi »
I like it. Thanks for sharing.
MNOSD member 0011
Soanso McMasters
I went and grabbed some 60 grit sandpaper and finished the job. I’m happy with where it is now. Here it is next to a standard Delica and a Wharncliffe (Salt) Delica. The modded Delica is in the middle.
Coastal
Post by Coastal »
Nice job! Did you use a block, or lay the paper flat on a hard surface?
Soanso McMasters
The lock on this sucker is rock solid. I was putting a lot of pressure on the spine at times.
Last edited by Soanso McMasters on Tue May 17, 2022 6:35 pm, edited 1 time in total.
Soanso McMasters
Coastal wrote:
Tue May 17, 2022 6:24 pm
I laid it on my kitchen table and went to town!
