Finger choil
Finger choil
Hi everybody,
I was wondering if you use the forward fingerchoil on your para's. I do not use it on the PM2 but do on the para 3. What are the intentions of the design? What are your thoughts?
Re: Finger choil
Choked up using the choil definitely gives you better control of the blade for certain cuts. Including the tip. Hard cuts wear you you really bear down I prefer no choil models.
Definitely a preference. My current preference is choil on smaller models. Feels more secure in hand for me. Longer models like the Endura, I have some extra handle at the end so it doesn't feel insecure without the choil. On a model like the Para 3 or Native 5, my hand comes to the end of the handle using the choil. I like the compactness of those models for certain circumstances. I also like the choil on those models because my hand feels locked in and not able to slip off the end of the small handle.
Re: Finger choil
I like finger choils on slippies for safety.
Re: Finger choil
I prefer them for safety, if the lock fails/accidentally closes then the choil will hit your finger instead of the blade edge.
Re: Finger choil
I sorta have to on a Para 2 because my hand doesn't fit very well behind it. Basically for me it comes down to size...if the handle is big enough to accommodate my hand without a choil, I'd rather not have one and would prefer it was something like a Caribbean, but on everything smaller where the handle isn't big enough for my hand I can live with them.
Re: Finger choil
I don't object to the concept, I just find myself preferring knives that don't have/need one. The big, big exception is the Military, an all-time favorite. I think the Stretch 2 XL will fall into that category as well. To answer the OP's question: no, I tend not to use it on the Para 2, and I don't have a Para 3.
Re: Finger choil
While I'm almost certain I've taken advantage of them a handful of times I cannot clearly remember any specific instance of utilizing a choil. I generally prefer knives without them but I don't mind them, especially on Spydercos where I feel like a greater majority of the knives have them, and like others have mentioned the added safety is nice to have.
- spydergoat
Re: Finger choil
I like it on small knives also, espcially on the Dragonfly 2. With the 5050 choill and top and bottom gimping and the ergos of the handle, I can really pinch that blade and lock it in my grip and manipulate it easily.
Re: Finger choil
Fine cutting = Choil
Heavy cutting = No choil
Re: Finger choil
I like how the choil feels while holding a knife but seem to use them more without the choil. I have no idea why.
- billdoier72
Re: Finger choil
I love the forward choil so much I won't even buy a knife without one.
Delica 4 VG10 - Dragonfly 2 K390 Warnnie - Chaparral CTS-XHP - Native 5 M4/Rex/45/4v - Para 3 CTS-BD1/Maaxamet/4V/20CV - Lil Native - Cruwear - Sage 5 S30V - Jester 4V
Re: Finger choil
i don't have a para 2, but i definitely use it on my manix. even though i have a full grip behind the choil, i prefer to use it because i like the feeling of the jimping and the way the knife fits/locks into my hand in that grip.
C253GBBK, C258GFBL, C101GBBK2, C11GYW, C11FWNB20CV, C101GBN15V2, C101GODFDE2, C60GGY, C149G, C189, C101GBN2, MT35, C211TI, C242CF, C217GSSF, C101BN2, C85G2, C91BBK, C142G, C122GBBK, LBK, LYL3HB, C193, C28YL2, C11ZPGYD, C41YL5, C252G, C130G, PLKIT1
CPM 20CV, CPM 15V, CTS 204P, CPM CRUWEAR, CPM S30V, N690Co, M390, CPM MagnaCut, LC200N, CTS XHP, H1, 8Cr13MoV, GIN-1, CTS BD1, VG-10, VG-10/Damascus, 440C
- araneae
Re: Finger choil
I use both grips, depends on the task and the knife.
-Nick
Last in: N5 Magnacut
-Nick
- kennethsime
Re: Finger choil
I do enjoy them on small knives, and I do use them on the PM2. Like David, this is largely a consequence of hand size - my hand doesn’t really fit well without the choil.
I was a die-hard choil guy for a long time, but recently have come around to the idea of losing it, especially on larger knives where you might use a hammer or saber grip for heavier cuts.
Re: Finger choil
I still prefer more edge and no choil. I am getting use to a choil on the Para 3 Spy 27, I would not have bought this knife were it not for the steel. I took the small size and choil on as a growth opportunity, learning time. I'm a couple years in now and I like the Para 3, I use the choil, but I have no intentions on buying another choil knife. Unless, Spyderco does a Para 3 in Vanax.
Spyderco: Tenacious G10, Waterway, Para 3 Spy27, Pacific Salt H1, In the Mule Team Stable(Z-Max, Z-Wear, S45VN, Magnacut, SRS13/SUS405, M398, Aeb-l, 15v)
Re: Finger choil
It's the precise opposite for me.billdoier72 wrote: ↑Mon May 16, 2022 6:55 pmI love the forward choil so much I won't even buy a knife without one.
I strongly dislike the 50/50 choil as implemented on the Para 2/3, Native/Chief, etc I stopped carrying (or sold) those knives and I will no longer buy a Spyderco that has it.
On the other hand, I still enjoy a lot the minimalistic choil of the Military / Para 1 and I can tolerate wider choils with a less pronounced prong, as seen on Kapara, Calypso Jr, Kriss.
All good, just different?
Re: Finger choil
Soanso McMasters wrote: ↑Mon May 16, 2022 6:51 pmI like how the choil feels while holding a knife but seem to use them more without the choil. I have no idea why.
I end up doing the same in all but the rarest situations where a choil might actually help with control or something. A Shaman feels fantastic to me on the choil but like someone else mentioned recently it can create hot spots when using it that way hard or for extended periods. Then when I'm not using it I don't like how far away the edge is from my hand, further away means less power going into a cut.
Re: Finger choil
What do folks think of the choil as executed on the Manix versus other knives? Just curious; rarely hear anyone talk about that choil. I'm starting to wonder if its the relationship/presence of the thumb ramp and index finger that makes one more comfortable versus the other. Personally I prefer choils. For my medium to small hand it allows my thumb and forefinger to be in a more harmonious alignment than say the handle forward designs like the Alycone/Polestar and Tenacious/Persistance even though I like those designs as well. I need to dig my Rock Jumpers out to test but am guessing the very pronounced thumb ramp on those makes a difference.
Re: Finger choil
Personally, I love the Manix. I think it feels comfortable using the choil and not using the choil. I really like how it feels not using the choil, but your hand is too far back from the edge. Better feel when not using the choil for harder use, but you don't have as much leverage. Kind of a Catch 22. Now, if there existed a Manix where the edge came back about 80% and the handle went up about 20% to meet together, Oh boy Oh boy!Bemo wrote: ↑Wed May 18, 2022 6:52 amWhat do folks think of the choil as executed on the Manix versus other knives? Just curious; rarely hear anyone talk about that choil. I'm starting to wonder if its the relationship/presence of the thumb ramp and index finger that makes one more comfortable versus the other. Personally I prefer choils. For my medium to small hand it allows my thumb and forefinger to be in a more harmonious alignment than say the handle forward designs like the Alycone/Polestar and Tenacious/Persistance even though I like those designs as well. I need to dig my Rock Jumpers out to test but am guessing the very pronounced thumb ramp on those makes a difference.
