Reducing blade length
z1r
Re: Reducing blade length
Post by z1r »
zhyla wrote:
Sun May 15, 2022 8:18 am
Stones will take forever. Filing hardened steel isn’t particularly fast either.
I would do this with a belt grinder or bench grinder and dip it in ice water frequently to preserve the temper. Actually I have no idea if LC200N even has a temper but just to be on the safe side. Also tape everything off to keep dust out of the handle and go slow.
Seems you missed this part:
Soanso McMasters wrote:
Sat May 14, 2022 9:11 pm
I will have to do it by hand because I don’t have a grinder
cjk
Post by cjk »
@Soanso Mcmasters
Do you absolutely need one of the LC200N salt models?
Spyderco makes an Endela, which like a just under 3.5" Endura. You wouldn't have to shorten it.
They also make a Stretch 2 which is under 3.5" and the new linerless Stretch 2 XL which is just under 4".
Soanso McMasters
Post by Soanso McMasters »
I really want one in LC200N. My son talked me out of my Wharncliffe Salt and I have no idea when my preorder Native with Magnacut will arrive. I want something I can abuse and sweat on for gardening, yard work, fishing, etc. and after carrying the Stretch I am appreciating the extra blade length.
Btw, I have a stretch 2 in k390 and love it! It’s my most carried knife for the last month.
Soanso McMasters
I may get one and do it by hand and post up some pics here just for anyone else thinking of doing the same. Still kicking it around.
Wandering_About
Post by Wandering_About »
For 1/16 of an inch, stones will do fine. A very coarse stone to start with. LC200N works fairly easily (says the guy that reprofiles Maxamet for fun) so a little reshape should not be too bad. Just don't get crazy ambitious and try to reshape the whole blade! I would not hesitate to take on that job. Of my stones, the Atoma 140 would get used for the rough work. You may want to try some low grit sandpaper if your coarsest stone is not very coarse.
Just be careful with a knife with an upturned edge (might be good to tape over the edge for a little protection). And try your best to keep the knife at 90 degrees to the stone.
MNOSD member #0035
Soanso McMasters
As a bit of an experiment I am working on grinding the spine on my 20CV Wharncliffe Delica with stones and sandpaper. I’ve definitely made progress over about an hour but it’s a task. If it comes out alright I’ll probably pull the trigger on the Pacific Salt 2.
Bloke
Post by Bloke »
Sun May 15, 2022 5:09 pm
you can rent a sander where I live for $5-10 and get the job done in five minutes. maybe try that?
:unicorn
Soanso McMasters
Dang this is quite the project! Two hours in… definitely getting the spine straightened but it’s quite the effort.
metaphoricalsimile
Post by metaphoricalsimile »
Sun May 15, 2022 9:52 pm
Keep in mind 20cv is like three times the wear resistance of LC200n.
Soanso McMasters
Sun May 15, 2022 9:03 pm
I have a Dremel and considered using that, per Evil D’s recommendation, but I don’t want to jack up the heat treat on it or remove too much material. I’ll just keep at it and see where I end up. I think it should look good once done, but I won’t be trying to remove this much material on 20CV by hand again!
Soanso McMasters
#32
Bloke wrote:
Sun May 15, 2022 8:42 pm
Have you re-worked any of those yet? Looks like a big job!
Bloke
#33
Post by Bloke »
Mon May 16, 2022 5:10 pm
Ah, hahaha! No mate, that’s just a pic I found and thought it quite funny that anyone could snap so many tips.
I’m either lucky or careful and don’t think I’ve ever snapped a tip though I’ve dropped a couple of knives and damaged tips.
Soanso McMasters
#34
Bloke wrote:
Mon May 16, 2022 7:11 pm
Well, I hope whoever it was got the can of paint open…
