Mini Yojimbo Prototype ?
northern munkey
Re: Mini Yojimbo Prototype ?
#161
Post by northern munkey »
Sorry if this has already been answered, just asking for handle length, as here in NZ for carry on luggage and in city's the rule is a handle of no more than 95mm (3.7"). It would be an ideal edc for me here if it fits within this rule. I carry a lil' native for this purpose.
Stuart Ackerman
#162
Post by Stuart Ackerman »
Northern Munkey...
If you look at the proto image, and measure the blade length of 2.5 inches against the scales, it might be just a tad under the NZ legal requirement?
Last edited by Stuart Ackerman on Tue Jan 24, 2023 1:48 pm, edited 1 time in total.
Dodge
#163
Post by Dodge »
Gonna have to add this to the short list and start saving.
Flash Batch request: Flat Iron Salt (CE w/ yellow FRN)
New knife request: Police 4 Salt!!!
“Don’t be so open minded that your brain falls out”
#164
RamZar wrote:
Fri Jan 20, 2023 4:48 pm
There’s still no MiniJimbo with a blade length of 2.99” for jurisdictions where there are such limitations.
There is the original Yojimbo 1 that has a blade length of about 2.9" -- it just isn't mini, it has a very large handle! I've always wanted to convert it into a smaller handled knife...the YoJimBob.
Cheddarnut
#165
Post by Cheddarnut »
Im going to rob a bank with a spoon to balance things out a bit.
RamZar
#166
Post by RamZar »
Bolster wrote:
Sun Jan 22, 2023 4:55 pm
Yes. Spyderco changed the blade length from 2.875" (73mm) on the original Yojimbo to 3.20" (81mm) on Yojimbo2.
It would be nice if we had models for various common legal blade lengths: 2.49” (63mm), 2.99” (76mm), 3.49” (88mm) and 3.99” (101mm).
The reason for say a blade length of 2.99” is because some jurisdictions say the blade length must be under 3 inches and some say the blade length cannot be more than 3 inches.
#167
We will have that with the introduction of the Microjimbo. A 2.49” blade easily fits under a 3” limit.
-Nick :bug-red
RamZar
#168
Post by RamZar »
Mushroom wrote:
Sun Jan 22, 2023 7:06 pm
Yes but if the limit in my area is under 3 inches I want a blade length as close to 2.99” as possible. That’s why I go for Chaparral or Native5.
#169
RamZar wrote:
Sun Jan 22, 2023 6:59 pm
Sounds like a good idea to me! This is off topic but, how does one officially measure the length of a blade, especially if you're going to two digits after the decimal? I'm looking at a Yo1 as we speak, and because the front of the handle is curved, there are various measurements that can be taken.
I'd want the blade shy enough of the legal maximum that a power-crazy prosecutor out to "make his bones" didn't "round up" to an illegal length.
RamZar
#170
Post by RamZar »
Bolster wrote:
Sun Jan 22, 2023 8:18 pm
The standard for blade length measurement is:
Where a statute, regulation or ordinance refers to knife blade length, the measurement shall be the straight line extending from the tip of the blade to the forward-most aspect of the hilt or handle.
#171
RamZar wrote:
Sun Jan 22, 2023 8:31 pm
Excellent. Did not know. Thanks! By that measurement the Yo 1 is just 2-3/4".
northern munkey
#172
Stuart Ackerman wrote:
Sat Jan 21, 2023 7:55 pm
Northern Munkey...
If you look at the proro image, and measure the blade length of 2.5 inches against the scales, it might be just a tad under the NZ legal requirement?
Kia ora Stuart, fingers crossed as it would be a great travel companion (I really like this knife)
RamZar
#173
Post by RamZar »
Michael Janich on his upcoming MicroJimbo at 11:56 time mark.
https://youtu.be/djfaFkiBXfc
p_atrick
#174
Post by p_atrick »
RamZar wrote:
Sun Jan 22, 2023 7:13 pm
It's not the same knife, but the Lil' Temperance 3 LW is fantastic. You get the blade length you need with a nearly maximized cutting edge. I was pleasantly surprised by that model. Of course, there are well-documented reasons why many will likely pass on the model.
RamZar
#175
Post by RamZar »
Hope to get some specs filled in (highlighted):
  • Overall Length: ?
  • Blade Length: 2.5”
  • Cutting Edge: ?
  • Blade Thickness: ?
  • Blade Material: CPM-S30V
  • Blade Style: Wharncliffe
  • Grind: Full Flat
  • Finish: Satin
  • Edge Type: Plain
  • Handle Length: ?
  • Handle Material: G-10
  • Color: Black
  • Frame/Liner: Steel
  • Weight: ?
  • User: Right Hand, Left Hand
  • Pocket Clip Tip-Up, Tip-Down
  • Opener: Thumb Hole
  • Lock Type: Compression Lock
  • Designer: Michael Janich
  • Country of Origin: USA
cabfrank
#176
Post by cabfrank »
I have been wondering about the weight also. I assume it's close to the Lil Native (2.5 oz), but...
RamZar
#177
Post by RamZar »
I got the additional specs (highlighted in yellow) for the MicroJimbo prototype from Michael Janich. Please be aware that the final specs for the regular production version may or may not vary slightly.
  • Overall Length: 6.18“
  • Cutting Edge: 2.17”
  • Blade Thickness: 0.145”
  • Grind: Full Flat
  • Finish: Satin
  • Edge Type: Plain
  • Handle Length: 3.80”
  • Color: Black
  • Weight: 3.1 oz
cabfrank
#178
Post by cabfrank »
Thanks. I imagine the production version specs will be close. It's a bit heavier than I guessed, but I really like the design.
V1.5
#179
Post by V1.5 »
Yep pretty much an instant buy when it's released. I like the evolution of the design. I love my Yojimbo 1 & 2.
max808
#180
Post by max808 »
At the risk of violating forum protokol, just look at the blade centering on this puppy...
