Vivi- how did you reshape the spine for this? I would love to try a Pac Salt with more acute tip.
Just cuts
- spydergoat
Re: Just cuts
Re: Just cuts
https://www.harborfreight.com/1-in-x-30 ... 61728.htmlspydergoat wrote: ↑Thu Apr 21, 2022 5:54 pmVivi- how did you reshape the spine for this? I would love to try a Pac Salt with more acute tip.
works better for my uses
- PeaceInOurTime
Re: Just cuts
Cut a hole in a bucket to try to grow an upside-down tomato plant.
https://youtube.com/shorts/5MhNdhSluoo?feature=share
- Makunochimaster
Re: Just cuts
delica-204p vs fruits
Native 5 cpm-s110v G10. Native 5 cpm-s110v frn.
Lil' Native MB cpm-s30v. Dragonfly 2 zdp-189.
Delica 4 cts-204p limited. Cricket Nishijin blk vg10.
Urban n690co. Persistence s35vn lightweight.
- Librarian
Re: Just cuts
- Spyderco delica zdp-189 14dps, regrind ~ 0.2 mm bte
Finish Grinderman SiC b1000vk(FEPA)
Finish Shapton 5000 grit (JIS)
Re: Just cuts
PeaceInOurTime wrote: ↑Fri Apr 22, 2022 11:50 amCut a hole in a bucket to try to grow an upside-down tomato plant.
- Connor
- Librarian
Re: Just cuts
REGRIND Vs. STOCK
- Dark Green delica - zdp-189 regrind bte 0.005" 17dps VS blue delica vg-10 stock bte 0.03" 17 dps
Re: Just cuts
Those are some pretty impressive videos. Is your rolled up magazine video a fresh edge, or was that after the wood cutting?
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
17 Spydies, 14 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
- Librarian
Re: Just cuts
The knife was after sharpening. But after woodworking, usually, the knife becomes a little dull and it would be enough for cutting a magazine.
Spyderco Urban k390 ~16dps, bte ~0,45 mm
Finish Grinderman (SiC) b1000vk (FEPA)
Re: Just cuts
Got a piece of glass in my finger. Used my manix2 with cruwear to slice under the glass and pop it out.
18* per side bevel, polished to .5 micron with 21* per side micro bevel sharpened to 2200 grit diamond.
Re: Just cuts
Cutting some BESS Test media with my S30V Shaman.
Slightly sharper than a utility razor.
15DPS Sharpmaker Diamond, CBN, Medium, Fine, Ultrafine. Stropped with KnivesPlus Strop Block.
Re: Just cuts
Spyderco: Tenacious G10, Waterway, Para 3 Spy27, Pacific Salt H1, In the Mule Team Stable(Z-Max, Z-Wear, S45VN, Magnacut, SRS13/SUS405, M398, Aeb-l, 15v)
Re: Just cuts
That delica ZDP-189 regrind is a beast. That blade eats wood. Geometry is everything.
