Okat this may be a silly question but when I want to loosen/tighten the pivot on a manix 2, native chief, PM2… am I supposed to be tightening only one side to make fine adjustments? I find if it’s relatively loose, I get a bit of blade play but when I tighten both sides up slightly, it becomes stiff.
Any suggestions or is it just a matter of tinkering until you get it?
Thanks
Pivot adjustments
- Godzilla68
Pivot adjustments
PM2 Crucarta
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
- VooDooChild
Re: Pivot adjustments
Just do whatever works.
Spyderco has really tight tolerances and tuning a pivot by hand, especially on a comp lock, can sometimes be a pain. Some of mine seem to have a sweet spot smaller than a millimeter. If I can hit that spot then Im happy.
- Godzilla68
Thanks for the reply. That’s pretty much what I figured. I was worried maybe only one side was simply for fine adjustments. Back to tinkering.
PM2 Crucarta
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
I watch the tip of the blade for correct blade centering and also check for blade play to set boundaries first. After that, it is personal preference.
- Godzilla68
Thanks Kobold. Okay, so tightening one side too much uncenters the blade. I will check tomorrow and confirm that my blade is centered and fiddle with it.
PM2 Crucarta
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
I usually only do one side, but I have had one shaman where I needed to adjust both. I couldn't get good action with no play without messing with both sides. If that happens I will loosen both sides, tighten one to where it just starts to bottom out (just past snug), then fine tune with the other side. It works for me.
I don't mind a little play when the lock is disengaged. As long as it locks up solidly I'm fine with it.
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
Exactly the same way I handle this, has never failed.
15 's in 10 different steels
- Godzilla68
Thanks everyone. I really appreciate the responses.
PM2 Crucarta
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
- Godzilla68
Okay so I adjusted all of my knifes. Thanks for all the advice. Worked like a charm. I even removed the blade from my Caly 3.5 no issue.
Next - replace the ball lock on My manix 2 with red flytanium aluminum version and replace the bearing - with a ceramic bearing.
PM2 Crucarta
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
Chaparral CF
Gayle Bradley Bowie
Manix 2 M390
Native Chief Rex45
Caly 3.5
Delica ZDP189
