Pm2 oops & fix
Pm2 oops & fix
Well guys.. after a couple years I managed to break the tip off my pm2. I originally bent it slightly. It lived that way for months until I was sharpening it the other day and it bothered me to no end. My brilliant self thought I could coax it back straight. Bad idea.. obviously this didn't end well.. so I reshaped the end and here are the results. Opinions? Its bothering me because I love the straight spline pointy pm2 blades..
Re: Pm2 oops & fix
Dear Bustedaw11:
Nice work!
Stay safe,
Mike
Nice work!
Stay safe,
Mike
Re: Pm2 oops & fix
Looks like great work to me!
Re: Pm2 oops & fix
For sure, job well done on that fix!
15 's in 10 different steels
Re: Pm2 oops & fix
Welcome aboard.
That’s a nice fix on that PM2.
Re: Pm2 oops & fix
For sure, nothing wrong with your fix. I think it looks good, and it'll work fine, no issues.
That said, a straight edge (ruler, scale, etc...), a pencil/sharpie/..., some time (keeping the blade cool if you grind it in a way that would heat the blade), and you can "straighten" the spine giving you the look you prefer.
u.w.
u.w.
- VooDooChild
Re: Pm2 oops & fix
Embrace the regrind.
I actually ruined my tip after trying to re-satin finish the blade with a belt sander after a failed mirror polish attempt. And of course it was on my favorite pm2.
- bearfacedkiller
Re: Pm2 oops & fix
You got your pint back. Now just spend some free time straightening the rest of the spine. A piece of masking tape is a good way to mark a straight line while doing it.
The Delica and Endura come with dropped points and I have straightened a few.
Re: Pm2 oops & fix
Why?bearfacedkiller wrote: ↑Fri Jan 28, 2022 9:16 amYou got your pint back. Now just spend some free time straightening the rest of the spine. A piece of masking tape is a good way to mark a straight line while doing it.
I think the repair was a good one. Just wondering why the need to "straighten" the whole blade?
Re: Pm2 oops & fix
Your fix looks good! Should work fine. The pointy blades are nice but a subtle drop at the point is more durable, in the end. There's a reason the Endura/Endela/Delica series has a little drop at the tip of the blade.Bustedaw11 wrote: ↑Thu Jan 27, 2022 7:31 pmWell guys.. after a couple years I managed to break the tip off my pm2. I originally bent it slightly. It lived that way for months until I was sharpening it the other day and it bothered me to no end. My brilliant self thought I could coax it back straight. Bad idea.. obviously this didn't end well.. so I reshaped the end and here are the results. Opinions? Its bothering me because I love the straight spline pointy pm2 blades..
MNOSD member #0035
MNOSD member #0035
Re: Pm2 oops & fix
Kinda why I like my Endela so much. Then again, I try very hard to resist the urge to use my knives as prybars. Must resist!Wandering_About wrote: ↑Fri Jan 28, 2022 11:30 amYour fix looks good! Should work fine. The pointy blades are nice but a subtle drop at the point is more durable, in the end. There's a reason the Endura/Endela/Delica series has a little drop at the tip of the blade.Bustedaw11 wrote: ↑Thu Jan 27, 2022 7:31 pmWell guys.. after a couple years I managed to break the tip off my pm2. I originally bent it slightly. It lived that way for months until I was sharpening it the other day and it bothered me to no end. My brilliant self thought I could coax it back straight. Bad idea.. obviously this didn't end well.. so I reshaped the end and here are the results. Opinions? Its bothering me because I love the straight spline pointy pm2 blades..
- bearfacedkiller
Re: Pm2 oops & fix
The drop on the Delica and Endura was a later change to reduce warranty claims. They used to be sort of value knives for the average Joe and I think they were getting lots of reports of and warranty claims for broken tips. Early versions of both had a straight spine.
There isn’t a right answer here. Some folks value a more durable tip and some, like myself, value a more acute tip.
Re: Pm2 oops & fix
Thanks much for the welcome and opinions guys!
I will probably leave it as a reminder and buy a new 1 for the original feel when I want it. :)
Side note- I actually bent the tip via a zip tie! I was tryin to get the point in there and musta put a little more pressure on her then I thought. Then things went bad tryin to fix that as I said.
Re: Pm2 oops & fix
Your blades looking like a pm3 here, I kinda dig it!VooDooChild wrote: ↑Fri Jan 28, 2022 9:03 amEmbrace the regrind.
Re: Pm2 oops & fix
Looks like making the best of a bad situation to me.. well done Bustedaw! Welcome.
Rick H.
Re: Pm2 oops & fix
But a pair of diagonal pliers for cable ties. Much better tool for the job!Bustedaw11 wrote: ↑Fri Jan 28, 2022 12:55 pmThanks much for the welcome and opinions guys!
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
Re: Pm2 oops & fix
I use my knives for everything man. I rarely have an issue and I am extremely picky about my folders staying as pristine as can be lol. I carry to much on me to pocket anything more like side cutters also. Also got 3 young ones and seems like about every darned toy they get is loaded with zip ties holding them in anymore. I'm sure if you have kids you understand how the toys get opened in the car on the way home, and not when you get home to your side cutters lol.
Re: Pm2 oops & fix
I only have so much room in my pockets, and don't always want to take an item to my tool room to cut a cable tie off, so I'm going to stick to pocket knives for 99% of my cable tie cutting.
- kennethsime
Re: Pm2 oops & fix
Great job! Looks like an Endela now.
Re: Pm2 oops & fix
Thanks!
