For me, it is more about the belly towards the tip to get that Wharnie kinda feel. So the Endura with less belly almost achieves that feel with a slight belly to make it more versatile than a Wharnie. Personally I don't prefer the extra belly even though it is probably more versatile overall. As far as belly at the tip, think Manix. All belly but not a hugh curve, so you almost get the same cutting ability at the tip as a Wharnie.Wartstein wrote: ↑Fri Jul 29, 2022 2:06 am
Also, and despite sounding like a broken record: Does no one else notice/feel the difference in the "cutting characteristic" between the over a long section totally straight Stretch edge (offers a bit of "wharnie power") and the continous curve in the Millie/PM2 shaped edges?
Now if you are cutting down boxes with the back of the blade, then I can see how the straight edge would feel similar. Even then I like to cut with a little angle. I wouldn't cut at a 90 degree angle.
Fortunately, belly or no belly, most of Spydercos core designs have that negative blade angle. So they all cut excellently.
