Time for a Pro-Grip update - Need input
Postby sal » Mon Sep 01, 2003 12:00 am
We think it is time to update the Pro-Grip. The design philosophy is for a "Hunting design" with EDC capability. I do have a rough plan in mind. My current plan is an up-size to 3.5"-3.75" blade, full flat grind VG-10 and a new name. I have some thoughts and dwgs, but I would like to hear your input.
nick
Postby nick » Mon Sep 01, 2003 11:34 am
i like the size of the pro grip as it is but would like to see a bigger jester in s/s (about 4"closed)
nick.
chux
Postby chux » Mon Sep 01, 2003 11:39 am
Hi Sal,
I think I would like to see a pro-grip with full PE and a separate ss clip. Keep the general blade shape and kraton inserts though. I certainly like the vg-10 steel for the bloade.
J Smith
Postby J Smith » Mon Sep 01, 2003 11:44 am
3.75" blade, full flat grind VG-10,PE and G10 scales.Now that would be better than the Wegner.Is there anyway to make G10 in camo?
Name Spyderco Outfitter or Spyderskinner
I learn something new everyday,even though I don't want to. Jeff
java
Location: Rosamond - Tropical Paradise without the tropics.....(or the paradise)
Postby java » Mon Sep 01, 2003 1:09 pm
Sal,
Hmmmm... Hunter/Pro-Venator/Pro-Grip... A Pro-Ven Hunter II?? The knife certainly has pro-ven itself capable of any tough chore. Great ergos and love the grippy Kraton inserts on the handle and clip.
Why not S30V?
Keep the same ratio of belly when you extend the blade.
Ridges behind the hole on the spine.
Lmited runs of Ti, G10, and CF handles might keep me off of Tim's site for a while as long as you're open to suggestions! <img src="smile.gif" width=15 height=15 align=middle border=0>
Stay safe! Stay sharp!
Ted
Postby Ted » Mon Sep 01, 2003 2:11 pm
Make it 3", G-10 with a compression lock.
VG-10 with flat-grind would indeed be very nice.
Needs to have an open spine like the Military for easy cleaning since it's a hunters knife.
I think 3.5"-3.75" would make it too big for an all-round EDC/Camping knife. And it would have serious competition from the Tim Wegner Professional Hunter.
Ted
druid
Postby druid » Mon Sep 01, 2003 10:04 pm
It is a privilege to have this opportunity. The larger tracks pro grip would solve most of my problems with the knife. I would love to see a compression lock or better yet that stainless steel frame lock you are talking about with the ATR. If construction stays the same about G. 10 with the same inlay a bowe Dent and the drop tip blade from that 3 oz. fixed blade, sorry I can't remember the name the upswept would be more traditional but I personally think the drop tip is more functional for everyday carry and better looking I would like a 75-25 with emphasis on seriation with a variation to fit the dynamics of the blade. Thank you very much.
druid
Postby druid » Mon Sep 01, 2003 10:08 pm
P. S. I started drooling when I saw the prototype Wagner tracker if that helps. Can you order the mouse through S. F. O. thanks again!!!!
druid
Postby druid » Mon Sep 01, 2003 10:12 pm
Sorry but I found the Wagner to be a little bit too wide at the bottom it kinda pinched my fingers and I have a big hand, I like the thick blade that may be smoothing out that nine degree angle on the liner would have helped if it was a true 90 degree angle? Please do this again I love this.
midget
Postby midget » Tue Sep 02, 2003 10:52 am
How about one with a deep choil built into the blade/handle?
Also, check the lock design- I experienced lock failure with my last one (maybe I got a dud?).
And a metal, wire clip would be great.
Thanks!
Alan2112
Postby Alan2112 » Wed Sep 03, 2003 1:44 am
Sal, don't make it with a 3.75" blade; it would indanger our precious Military! Plus, I've got all the large folders I really want! RKBA!
dynaryder
Postby dynaryder » Wed Sep 03, 2003 2:11 am
3.25" blade would be nice. Drop the SS version for G-10. And how about giving the FRN some Native 3D treatment? More ergo handle w/finger reliefs plus ambi wire clip.
JMHO,but I wouldn't consider a compression lock. On an MBC like the Gunting,fine. But on an EDC they're a pain to use. Hey,how about dumping the SS for camo or OD G-10 w/a Ball lock? With a 3.25" blade,that would rock!
shootist16
Postby shootist16 » Wed Sep 03, 2003 1:28 pm
Ideally it would be available in plain edge. I like the g-10 idea, but that really depends on the market segment you are trying to capture. If not g-10, I agree with Carlos... 3d FRN w/ bi directional volcano grip.
And a nice large thumb hole.
Large choil area for choking up.
What are the pro's and con's of different colors?
Pro's:
Different color may be found easier if dropped in the woods
Different color may be more sheeple friendly
Con's
Depending on color, may not have mass appeal
May not be "subdued" enough for some hunters/outdoorsman
About the name, if you give it a hunting name it will kill the edc/mass market appeal. Take a look at the Wegner. Awesome knife. It makes a great EDC, but more marketing should have pushed the edc aspect. Your average Joe may not look at it if it is marketed strictly as a hunter. By all means say that it is an excellent hunting knife, but package it as more of the edc aspect.
Dennis Bible
Edited by - shootist16 on 9/3/2003 1:30:05 PM
dialex
Postby dialex » Thu Sep 04, 2003 12:21 am
The Pro-Grip isn't quite my style; it's among my wife's favorites, as usually <img src="wink.gif" width=15 height=15 align=middle border=0>
But...
I remember I've seen at hamonoichiba.com a knife they called Spyderco "K" and it looks like a FRN Pro-Grip with a C05 Standard blade. Now I know that the particular blade shape of the Standard is not quite suitable for hunting... but I like the way it looks.
Maybe that integral zytel pocket clip should be replaced with a metal one, like the Calypso jr.'s
<a href="http://users.pcnet.ro/dialex"><font color=blue>(my page)</font></a>
druid
Postby druid » Thu Sep 04, 2003 11:00 pm
The calypso Jr. in the 2000 catalog blows doors off any frn I've ever seen. Something like that in 3-D. g10????
Seriously the detail work on the knife is great I almost listed at all but you just might just be familiar with it.;]
druid
Postby druid » Thu Sep 04, 2003 11:27 pm
They can help it, what about 3-D frn on one side and the steel frame lock on the other. Traditional rubber patch on steel side, bars or tiger stripes on the other on the off-chance that in laying on a 3-D surface isn't complicated.
Carlos
Postby Carlos » Sat Sep 06, 2003 10:35 am
BTTT
philuk44
Postby philuk44 » Sat Sep 06, 2003 11:25 am
Wouldn't change much about the Pro-grip myself - I really like the design. PE option would be nice and maybe change the clip to plain S/S - I could live without the kraton in the clip. Just my humble opinion..............
Phil
Alberghini
Postby Alberghini » Sun Sep 07, 2003 10:30 pm
My opinion is: Plain Edge, G-10 with steel liners handle, lockback or compression lock, and Ambidextrous clip please!
bildrac
Postby bildrac » Mon Sep 08, 2003 6:27 pm
Other than 'adding' the option for tip-up carry, and changing the lock to a compression lock, there is not much that I'd change on it. It fits my hand very well, and feels more comfortable than many fixed hunters. And personally, I disagree with the notion that a compression lock is not EDC usable (strictly personal opinion based on my own daily usage), I use my Gunting as an EDC despite it's obvious MBC design (it's a great usable knife for most tasks), and find disengaging the compression mechanism quite easy to do. Bottom line, familiarity, plus, I won't use a utility knife if it has either a liner lock or lockback, way too many closecalls (albeit, most of them were with well used knives).
Edited by - bildrac on 9/8/2003 6:34:05 PM
Users browsing this forum: Ankerson, Bing [Bot], Bloke, Granoo Fink, knife__bro69, Nemo3000, qwkzotc and 67 guests
