New Knife Steel Ratings by Knife Steel Nerds
- Brock O Lee
Re: New Knife Steel Ratings by Knife Steel Nerds
How low to drop the edge angle? It’s like tightening a fastener. Tighten until you strip the threads, then back off a quarter turn...
Thank you Larrin….your work is appreciated!
It's important to note that these are "ideal" values for edge retention. They diverge significantly from industry standards and how some of these steels actually perform in the knives that use them.
For instance, notice that 8Cr13Mov, 14C28N, and Nitro-V have equal edge retention ratings while 440A has a higher rating. Does this surprise anyone else? Using current production knives in these steels, Nitro-V and 14C28N have significantly better edge retention than 8Cr13Mov and 440A.
I'd love to see this addressed by Larrin. I've wondered why these trends exist and whether some of these steels are just easier to heat treat at the mass-production level. For instance, I often get better edge retention from 12C27 than I do 8Cr13Mov. Why is that?
chronovore wrote: ↑Wed Oct 20, 2021 4:03 pmIt's important to note that these are "ideal" values for edge retention. They diverge significantly from industry standards and how some of these steels actually perform in the knives that use them.
He clearly states the following in the article:
" The ratings I have are for an “optimal” heat treatment. By that I don’t mean that a better heat treatment is not possible, but that major mistakes in heat treating are avoided. It is certainly possible for a knifemaker or heat treating company to do a heat treatment that will have suboptimal properties. I have an article that lists off the major mistakes often made in heat treating. "
And even cites another of his articles that goes into all the ways manufacturers can screw up heat treats. What more do you want?
chronovore is making a different point than the one you're answering. they're rightly highlighting the abstraction of the charts, and nodding to the multitude of variables intrinsic to actual production processes and material reality. by abstraction i don't mean 'absence of data gathered through experimentation.' i mean what its author has acknowledged: interpretive idealization based on explicit parameters, shared standards and definitions, and experimental data produced within those confines, aka what any classic positivist would describe as "science." the graphs/results as a whole represent a data value of let's call it "1;" there is value in them by a specific definition (vs. for instance, the value of X knife tester's results on YT) because of the rationalized approach taken in the generation of that data, which has then been translated into graphic representation here. but as I expect their author would readily acknowledge, they are only one collection of results, achieved in specific ways, using specific decisions and specific samples, that in order to be truly generalizable would require much more experimentation with equally defined parameters, using the same and different methods. the author's core claim is that their results are measurably superior to the Minnowesque Vast Wasteland of 'steel ranking' nonsense out there, not that they are the final, only, or even the complete word on the subject. i'm sure more will come down the pike from others.Gtscotty wrote: ↑Wed Oct 20, 2021 5:35 pmHe clearly states the following in the article:chronovore wrote: ↑Wed Oct 20, 2021 4:03 pm
but all that is beside the question chronovore appears interested in, as i undestand them: not simply about heat treats, but about the mix of complex variables that are consistent enough to result in 'real use' differences consistent enough for them to notice. whether or not that question can be easily or meaningfully answered is hard to say. one would have to know more details about the knives chronovore has used - and whether or not they're actually physically comparable in terms of edge angle, sharpening, stock, etc etc - that have led them to make this observation. but it's a harmless question/musing imo.
No, I believe I answered his question in the only reasonable way it can be answered, by asking "What more do you want?"bleasure wrote: ↑Wed Oct 20, 2021 6:36 pmchronovore is making a different point than the one you're answering. they're rightly highlighting the abstraction of the charts, and nodding to the multitude of variables intrinsic to actual production processes and material reality. by abstraction i don't mean 'absence of data gathered through experimentation.' i mean what its author has acknowledged: interpretive idealization based on explicit parameters, shared standards and definitions, and experimental data produced within those confines, aka what any classic positivist would describe as "science." the graphs/results as a whole represent a data value of let's call it "1;" there is value in them by a specific definition (vs. for instance, the value of X knife tester's results on YT) because of the rationalized approach taken in the generation of that data, which has then been translated into graphic representation here. but as I expect their author would readily acknowledge, they are only one collection of results, achieved in specific ways, using specific decisions and specific samples, that in order to be truly generalizable would require much more experimentation with equally defined parameters, using the same and different methods. the author's core claim is that their results are measurably superior to the Minnowesque Vast Wasteland of 'steel ranking' nonsense out there, not that they are the final, only, or even the complete word on the subject. i'm sure more will come down the pike from others.Gtscotty wrote: ↑Wed Oct 20, 2021 5:35 pmHe clearly states the following in the article:chronovore wrote: ↑Wed Oct 20, 2021 4:03 pm
Of course Larrin heat treated all the steel samples to a general optimal standard such that "major mistakes in heat treating are avoided." How else could he have generated the information for this comparison in a way that is useful or makes sense without using this sort of "best practices" baseline. Given that the goal was to give people easy and somewhat simplified guideline tools for comparing various steels available on the market there's really no other practical way to do it.
So back to What more does chronovore want?
- An enormous study that catalogs real edge retention, toughness and corrosion resistance values for all steel offerings from tens of knife manufacturers over decades of production?
Obviously this isn't remotely feasible, but without real "industry standards" for the heat treatment of all of these steels (that is the base assumption of the whole question anyway isn't it), how else can you get the more mass production representative values desired.
- Measured values that more closely match internet knife lore, preconceived assumptions, and subjective observations from using blades of varying geometry, optimization, sharpness, etc?
I suspect this is the real ask, but we are already awash in this kind of less than useful "information". The most interesting characteristic of Larrin's scientifically sound, transparent and repeatable data is that it does not fall into this cognitive trap.
Can you direct me to a few that are good? Thanks!Henry_P wrote: ↑Tue Oct 19, 2021 5:27 pmS90v lil native still in stock at many retailers.Wartstein wrote: ↑Tue Oct 19, 2021 4:30 pm
Are there any Spydercos in S90V in the current line up (and somewhat available)?
The point is more that the difference between these ideally heat-treated blades and the actual blades that people get IRL can be hugely significant and at least in some cases, consistent. Larrin is absolutely right about bad information being endemic. So I think it might have been worth spending a little more time on the difference between actual and ideal. It doesn't take tons of independent studies or whatever. There may be complications in running actual knives through CATRA but some of these trends are fairly well-known, either from serious use or less scientific but still reasonably consistent cut testers like Cedric & Ada, Super Steel Steve, and Outpost 76.Gtscotty wrote: ↑Wed Oct 20, 2021 8:22 pmNo, I believe I answered his question...bleasure wrote: ↑Wed Oct 20, 2021 6:36 pmchronovore is making a different point than the one you're answering. ...Gtscotty wrote: ↑Wed Oct 20, 2021 5:35 pmHe clearly states the following in the article:chronovore wrote: ↑Wed Oct 20, 2021 4:03 pm
I mentioned some of the steels with glaring exceptions. For those who have extensively used actual knives where these steels are used, you know that 8Cr13Mov tends to fall short of 14C28N, Nitro-V, and lots of other steels. Does anyone have extensive experience with current models in 440A, such as the inexpensive knives from Boker? Is actual performance better or worse than 8Cr13Mov?
We see a similar situation with D2. The current market is saturated with budget knives in D2. These are the "D2" knives that lots of people are going to get. Excluding brands like Eafengrow with false steel stamps, the D2 in these knives consistently falls short of expectations based on the ideal and can sometimes be outperformed by similarly priced knives in 14C28N or Nitro-V.
The fact that these differences exist is interesting and it may be valuable to explore that. As knife users, I think there is value to us in having knife ratings that better reflect these steels as we would actually be getting them. I'm also interested in why some steels seem to outperform their ideal or predictive values versus why some seem to consistently under-perform.
- Naperville
Spyderco has a good reputation for delivering knives with properly treated steels. I've never had a ton of money, and I don't have Larrin's expertise, so I buy Spyderco knives. I bought a few ZTs too, they seem to have a good reputation. I'd trust Buck, because the people doing their heat treat is well known. I don't have many Benchmade knives, but I'd imagine they are also OK.
It wasn't that long ago that manufacturers started using better grade steels, and until there are more tests run on the various knives, I'll just stick with what I know.
Very informative.
Definitely confirms, dispels and highlights various viewpoints.
“I don’t know, I’m a puppet!”
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
Agreed. I keep saying the CE Resilience in 8Cr is a very high performance knife for the $$. Takes a fantastic edge and holds it well enough for my day to day chores.z1r wrote: ↑Tue Oct 19, 2021 4:04 pmI have to agree, the 8Cr13NoV in my Byrds and Tenacious are head & shoulder above the same steel in another maker's knife I own. Night and day.zuludelta wrote: ↑Tue Oct 19, 2021 11:21 amI think otherwise decent, affordable steels like AUS-8/8Cr13MoV and 440C develop a bad reputation partly because the market is flooded with cheap knives in those steels that have been poorly heat-treated or have really terrible edge geometry.
Spyderco does a good job with its 8Cr13MoV knives, but there are so many companies out there that regularly pump out 8Cr13MoV knives with edges that are ground terribly, & therefore not giving the steel the chance to perform anywhere close to its potential.
My Rex45 Chief is around 13dps no microbevel. No issues with edge stability, and I've cut plenty of wood.Sharp Guy wrote: ↑Tue Oct 19, 2021 7:25 pmI reprofile all my knives to 15 dps and never have chipping issues. I whittle hardwood to test my edges and just kill time and never have a problem. I've reprofiled several HAP 40 knives but I guess I haven't done any of my REX 45 knives yet. Now I'm curious to see what'll happen. I'll do my Native LW first and then my Para 3 since I carry those the mostKarl_H wrote: ↑Tue Oct 19, 2021 4:37 pmI have a SUS410 clad HAP40 knife that is nominally heat treated to 65HRC, which seems significantly tougher than my REX45 Native 5.Wartstein wrote: ↑Tue Oct 19, 2021 11:56 am
As far as I know (just what I heard) HAP 40 is run "softer" than REX 45 indeed. They say HAP 40can´t be as hard due to the cladding with SUS410 (again, just repeating what I read).
Now, from what you say, being a bit softer could actually be an advantage.
Still: My REX 45 Manix LW seems to be really tough in my use (just like my HAP40 knives). Not a scientific measurement at all of course, and perhaps in the typical pocket knife use extreme toughness is of not much relevance anyway... unless it allows for more acute edge angles!
I reprofiled the edge bevel my REX 45 Native 5 to 15 degrees per side and have had a lot of chipping issues. I am trying to slowly increase the bevel angle, until I stop getting excessive chipping. Cutting rubber inner tubes and whittling wood did a lot of damage my edge.
This has not been my experience. I have gotten as good of edge retention out of Spyderco 8Cr as any 13C27 or 14C28N I've tried.chronovore wrote: ↑Wed Oct 20, 2021 10:10 pmI mentioned some of the steels with glaring exceptions. For those who have extensively used actual knives where these steels are used, you know that 8Cr13Mov tends to fall short of 14C28N, Nitro-V, and lots of other steels.
The swedish steels have an advantage in corrosion resistance in my experience though.
For those of us where corrosion resistance is of primary concern it’s good to see so many stainless steels we know side by side for toughness, edge retention and corrosion resistance. Wish H1 was included like others in the corrosion resistant 10 rating: LC200N and Vanax. I have some knives in H1 and LC200N but not Vanax yet. I’m much more familiar with those in the 9-9.5 corrosion resistant rating like: M390/20CV/204P (favorite EDC steel for corrosion resistance and edge retention in a small 3” blade length folder). Of course, MagnaCut is begging to be tried.
Thanks Larrin! ... I look forward to memorizing this!
RamZar wrote: ↑Wed Oct 20, 2021 11:03 pmFor those of us where corrosion resistance is of primary concern it’s good to see so many stainless steels we know side by side for toughness, edge retention and corrosion resistance. Wish H1 was included like others in the corrosion resistant 10 rating: LC200N and Vanax. I have some knives in H1 and LC200N but not Vanax yet. I’m much more familiar with those in the 9-9.5 corrosion resistant rating like: M390/20CV/204P (favorite EDC steel for corrosion resistance and edge retention in a small 3” blade length folder). Of course, MagnaCut is begging to be tried.
Interesting. I thought S45VN was supposed to have an advantage in toughness over S30V, but this chart shows them both rating a 4 in toughness.
I’m sure that actual use in various blades/grinds, heat treats, etc., will yield results that differ from the chart to varying degrees.
Double post
Makes me think if I should really wait for a Tenacious LW and full SE in S35VN... perhaps a full SE Tenacious in Spydercos 8CR is not that far behind, will hold an edge good enough (since SE holds an edge better than PE anyway) and will on top be easier to sharpen..(and then almost a steal for the price it comes...)
James Y wrote: ↑Wed Oct 20, 2021 11:54 pmRamZar wrote: ↑Wed Oct 20, 2021 11:03 pmFor those of us where corrosion resistance is of primary concern it’s good to see so many stainless steels we know side by side for toughness, edge retention and corrosion resistance. Wish H1 was included like others in the corrosion resistant 10 rating: LC200N and Vanax. I have some knives in H1 and LC200N but not Vanax yet. I’m much more familiar with those in the 9-9.5 corrosion resistant rating like: M390/20CV/204P (favorite EDC steel for corrosion resistance and edge retention in a small 3” blade length folder). Of course, MagnaCut is begging to be tried.
RamZar wrote: ↑Sun Oct 17, 2021 12:37 am
See article:
https://knifesteelnerds.com/2019/11/01/ ... 5vn-steel/
S45VN offers better corrosion resistance and toughness than S30V with the same edge retention.
This is what the S45VN Article said:
“The main changes we expect from S45VN vs S35VN and S30V are an improvement in corrosion resistance due to the increase in Cr of about 1%. We expect a reduction in toughness when compared with S35VN because of the increase in total carbide content. The design including niobium and nitrogen additions should help maintain toughness similar to or better than S30V.”
“S45VN has only slightly reduced toughness when compared with S35VN, and S45VN is an improvement over S30V, particularly when hardness is factored in:”
“The S45VN datasheet provides a number for CATRA edge retention relative to 440C, which it lists as 143%. This is in comparison with 440C which is 100%, S30V at 145%, and M390/20CV at 180%. However, the datasheet has an asterisk next to the 143% value and says that it is “based upon market feedback.” These estimates should perhaps be treated with some suspicion as the S35VN datasheet has the same asterisk for its 145% value which puts it at the same level as S30V, but independent experiments put S35VN around 132% at 61 Rc [8]. The same study found values for 61 Rc S30V at 149% and 61.5 Rc M390 at 179% [8], which are similar to those given by Crucible (though for 20CV rather than M390). However, Bob Skibitski of Crucible confirmed to me that the 143% number is based on actual CATRA experiments. Interestingly, the S45VN datasheet has a newly adjusted CATRA value of S35VN of 140%, better reflecting the somewhat reduced edge retention of S35VN when compared with S30V.”
Hi Larrin. Very nicely done! Thanx much for the work and for sharing.
