P'kal as EDC?
- Jim Malone
P'kal as EDC?
Thinking about buying a P'kal. Anyone carried one for a longer period of time as an EDC?
Any other feedback?
Thx.
Any other feedback?
Thx.
Re: P'kal as EDC?
Why? RGEI is great for a weapon and not great for opening Amazon packages or slicing apples. I think most who carry a PKal as a weapon carry something else for EDC. But I could be wrong
Re: P'kal as EDC?
I've carried a P'kal for my EDC & as a work knife... it can serve in those roles once you get used to it. You can put the clip on the other side so you can more easily deploy it in a conventional forward grip (out-of-the-box, it's configured for RGEI deployment). But in my mind, that sort of defeats the whole purpose of the design.
But if you really want one for use as an EDC folder, yeah, it can work as that for sure. But there are better designs for the role IMO: for example, the discontinued Li'l Temperance 3, if I remember correctly, was designed by Sal Glesser to be an MBC-rated, sub-3 inch folding knife with ergos that can support RGEI and conventional techniques.
Re: P'kal as EDC?
Mine has always been a dedicated SD knife. With the mindset that the edge should be as sharp as possible at all times. But something I recently heard from an instructor is changing my attitude on not using it as an EDC.Jim Malone wrote: ↑Sat Sep 25, 2021 3:42 pmThinking about buying a P'kal. Anyone carried one for a longer period of time as an EDC?
Any other feedback?
Thx.
They said if you're going to carry a knife for defense it is very important that you use it often for EDC tasks. This will help you understand the way it cuts and the mechanics of use in different situations. Being familiar with the knife in EDC use will make it easier to use in other situations.
I still think a well maintained edge is important, but I think there's a lot of wisdom in the idea of EDC use for SD knives. I'm going to pick up another P'kal and Emerson Elvia in the next few months, and try to EDC them.
On a related note I bought a Karahawk recently specifically for EDC use, and it works great.
Re: P'kal as EDC?
Carried a P’Kal daily as it was designed in the front upper corner of my pocket but it kept opening. It was so sharp it shredded my pants and I cut my hand a few times. Made me super careful about checking it regularly. I eventually switched to a Karahawk (waved) carried on my off hand side in the waistband left of my belt buckle. While I can easily deploy it with either hand but it is setup for my off side to get someone off me so I can access my other knife or pistol depending on the situation.
I do have a Spyderco reverse fixed blade that is fantastic for carry also.
M.N.O.S.D. 0031
Re: P'kal as EDC?
Hi DrHe,
Welcome to our forum.
Re: P'kal as EDC?
zuludelta wrote: ↑Sat Sep 25, 2021 4:48 pmI've carried a P'kal for my EDC & as a work knife... it can serve in those roles once you get used to it. You can put the clip on the other side so you can more easily deploy it in a conventional forward grip (out-of-the-box, it's configured for RGEI deployment). But in my mind, that sort of defeats the whole purpose of the design.
Hi Zuludelta,
Yes, that is true and I agree with you. BTW, we are currently tooling up for an FRN version of the Lil Temp 3.
- Jim Malone
Re: P'kal as EDC?
I have a P'Kal that is part of my carry rotation. I removed the wave feature and moved the clip so that it draws in a normal forward grip. I use it mostly for yardwork. I don't use folders for food prep, but I've wondered if it would feel like a Swayback or a paring knife when peeling an apple.
Re: P'kal as EDC?
I started using my Emerson Elvia for EDC today. It's similar enough to the P'kal to make a comparison.
It was.... interesting. I'm used to pull cutting boxes and packaging with my hawkbills, but it was taking a little mental adjustment to make all the pull cuts edge in. I'm starting to get the hang of it. We'll see how I feel after a week.
Re: P'kal as EDC?
I've owned the P'Kal model on two occasions over the years. I used to do a lot more trading that I currently do and I would end up with some pretty unusual knives at times because of my constant trading and checking out different models.
Both of the P'Kal models I obtained were plain edged models which at that time I really couldn't find any pending practical use for that model. I've wondered over the years what a P'Kal in full Spyderedge would be like and it's one model I would be willing to pay money to have someone like Willey knives put serrations on one just to see how it would perform. But I can't even imagine what I would use a plain edged P'Kal model for.
If I were to buy a particular Spyderco model strictly for self defense and martial arts which is what the P'Kal is basically designed for I would personally prefer the C-60 Ayoob model way ahead of the P'Kal. I'm not knocking the P'Kal because I'm sure it's great for what it's intended for. However unless I could get one in full SE I really doubt I would have any viable use for one in plain edge. But I bet it would be a beast in full SE.
Re: P'kal as EDC?
Great news!
Re: P'kal as EDC?
JD Spydo wrote: ↑Mon Sep 27, 2021 5:20 amBoth of the P'Kal models I obtained were plain edged models which at that time I really couldn't find any pending practical use for that model. I've wondered over the years what a P'Kal in full Spyderedge would be like and it's one model I would be willing to pay money to have someone like Willey knives put serrations on one just to see how it would perform. But I can't even imagine what I would use a plain edged P'Kal model for.
JD my friend youre love of Spyder Edge is constant and inspiring.
Sounds like a winner. Eager to see how it turns out.
Re: P'kal as EDC?
I think the P’kal is great for EDC, once you get used to RGEI
Matter of fact I remounted the clip on my waved delica and waved dragonfly to operate the same way as the P'kal. By EDC'ing the knife I use for martial arts. It made me realize that the choil on the dragonfly and the Ricasso on the delica often gets caught up while cutting certain materials. So you either have to train for that failure or find a knife that has a blade that extends to the handle
I’m still hoping the lil P’kal prototype goes into production. Does anyone have a pic or video of it?
Re: P'kal as EDC?
Where did you see lil P’Kal mentioned? I see Lil temp above, but haven’t seen Lil P’Kal ever mentioned and would be interested! It would be the smallest ball lock ever made I would thinkBlue72 wrote: ↑Sat Oct 02, 2021 8:29 amI think the P’kal is great for EDC, once you get used to RGEI
Re: P'kal as EDC?
Here is a relevant quote from the smaller Pkal thread.twinboysdad wrote: ↑Sat Oct 02, 2021 9:21 amWhere did you see lil P’Kal mentioned? I see Lil temp above, but haven’t seen Lil P’Kal ever mentioned and would be interested! It would be the smallest ball lock ever made I would thinkBlue72 wrote: ↑Sat Oct 02, 2021 8:29 amI think the P’kal is great for EDC, once you get used to RGEI
Re: P'kal as EDC?
I've been using my pkal style knife as an edc for about a week now. This morning I was breaking down some boxes with it, and noticed that it suddenly felt a lot less awkward than it did a week ago.
Re: P'kal as EDC?
Not sure how I missed this…I’m inZrowsN1s wrote: ↑Sat Oct 02, 2021 1:12 pmHere is a relevant quote from the smaller Pkal thread.twinboysdad wrote: ↑Sat Oct 02, 2021 9:21 amWhere did you see lil P’Kal mentioned? I see Lil temp above, but haven’t seen Lil P’Kal ever mentioned and would be interested! It would be the smallest ball lock ever made I would thinkBlue72 wrote: ↑Sat Oct 02, 2021 8:29 amI think the P’kal is great for EDC, once you get used to RGEI
Re: P'kal as EDC?
I absolutely love the P’kal. I just noticed in some grappling positions the large size makes it harder to deploy. Hopefully the lil P’kal makes production. If it doesn’t I hope Sal posts a pic of the prototype so I can have a custom knife maker cut mine down in size
Re: P'kal as EDC?
I couldn't see myself using one as an actual cutting tool.
But, I really REALLY think it would be awesome if more models were drilled to accept the little wave hook rod. I would love to be able to thread that in and use it whenever I wanted and remove it when I don't. That always seemed like an awesome idea that never was perused enough, right along with the Cobra Hood.
