Polished FRN?
Re: Polished FRN?
That is a result of the bug logo being polished in the molds that are used to make the handles.
-Nick
Re: Polished FRN?
It would not be difficult at all. They make shiny textured plastic toys all the time. Have you ever heard of legos? Legos have a very similar texture to the Bi-directional texture, and they make billions of those things all day long. It's not a difficult process at all.Mushroom wrote: ↑Fri Sep 24, 2021 8:42 amIt probably could be polished with sand paper and steel wool but post processing of FRN is not efficient in a production setting. This type of texture would be machined into the molds for FRN. The molds would need to be polished smooth to produce a smooth injection molded part.
It would be extremely difficult, if not impossible, to produce a polished bidirectional texturing.
Re: Polished FRN?
Yeah, I'm well aware of the process. Thanks.KnifusMaximus wrote: ↑Sat Sep 25, 2021 9:15 amIt would not be difficult at all. They make shiny textured plastic toys all the time. Have you ever heard of legos? Legos have a very similar texture to the Bi-directional texture, and they make billions of those things all day long. It's not a difficult process at all.Mushroom wrote: ↑Fri Sep 24, 2021 8:42 amIt probably could be polished with sand paper and steel wool but post processing of FRN is not efficient in a production setting. This type of texture would be machined into the molds for FRN. The molds would need to be polished smooth to produce a smooth injection molded part.
Believe it or not, the tolerances Lego is able to achieve with their blocks actually is extremely difficult at their level of production. They are masters of injection molding, it's actually quite impressive. Not a good comparison, in my opinion.
Also, which legos have a very similar texture to the bi-drectional texture? Just curious.
-Nick
Re: Polished FRN?
But Legos are small and for children...so they must be simple to produce!
So it goes.
Re: Polished FRN?
While comparing the handle of my Ramco to the Micarta scales on my C44 Dyad, it suddenly occurred to me that I have a very smooth and shiny rifle stock that I've had for over half a century. My Remington Nylon 66 has a stock of DuPont Zytel fiberglass reinforced nylon. Slick except where checkering is molded in, still shiny after all these years, it pretty well proves that FRN can be manufactured shiny if that was the original question. Whether you can polish it after manufacture to make it shiny is another question. It should be possible if you are determined and have lots and lots of free time to invest.
Re: Polished FRN?
I had forgotten about the Remington Nylon 66. Those things were very shiny and nearly indestructible.yablanowitz wrote: ↑Sat Sep 25, 2021 3:46 pmWhile comparing the handle of my Ramco to the Micarta scales on my C44 Dyad, it suddenly occurred to me that I have a very smooth and shiny rifle stock that I've had for over half a century. My Remington Nylon 66 has a stock of DuPont Zytel fiberglass reinforced nylon. Slick except where checkering is molded in, still shiny after all these years, it pretty well proves that FRN can be manufactured shiny if that was the original question. Whether you can polish it after manufacture to make it shiny is another question. It should be possible if you are determined and have lots and lots of free time to invest.
Re: Polished FRN?
Mushroom wrote: ↑Sat Sep 25, 2021 10:16 amYeah, I'm well aware of the process. Thanks.KnifusMaximus wrote: ↑Sat Sep 25, 2021 9:15 amIt would not be difficult at all. They make shiny textured plastic toys all the time. Have you ever heard of legos? Legos have a very similar texture to the Bi-directional texture, and they make billions of those things all day long. It's not a difficult process at all.Mushroom wrote: ↑Fri Sep 24, 2021 8:42 amIt probably could be polished with sand paper and steel wool but post processing of FRN is not efficient in a production setting. This type of texture would be machined into the molds for FRN. The molds would need to be polished smooth to produce a smooth injection molded part.
Have you ever seen a lego?
Re: Polished FRN?
Cylinders in neat rows arising from a flat plain are rather different from the continuous angled wedges arranged in arcs on a bidirectional texture. This is especially so with regard to polishing the molds. The handle texture is far more complicated.KnifusMaximus wrote: ↑Mon Sep 27, 2021 12:20 amMushroom wrote: ↑Sat Sep 25, 2021 10:16 amYeah, I'm well aware of the process. Thanks.KnifusMaximus wrote: ↑Sat Sep 25, 2021 9:15 amIt would not be difficult at all. They make shiny textured plastic toys all the time. Have you ever heard of legos? Legos have a very similar texture to the Bi-directional texture, and they make billions of those things all day long. It's not a difficult process at all.Mushroom wrote: ↑Fri Sep 24, 2021 8:42 amIt probably could be polished with sand paper and steel wool but post processing of FRN is not efficient in a production setting. This type of texture would be machined into the molds for FRN. The molds would need to be polished smooth to produce a smooth injection molded part.
Re: Polished FRN?
Nah, It's not difficult at all. I get it that you want to pretend that spyderco knives are some super complicated thing to make, but in reality, it's just a blade, a few screws, and some plastic. There is nothing technologically advanced, and nothing any toy company can't produce...Bill1170 wrote: ↑Mon Sep 27, 2021 5:03 amCylinders in neat rows arising from a flat plain are rather different from the continuous angled wedges arranged in arcs on a bidirectional texture. This is especially so with regard to polishing the molds. The handle texture is far more complicated.KnifusMaximus wrote: ↑Mon Sep 27, 2021 12:20 amMushroom wrote: ↑Sat Sep 25, 2021 10:16 amYeah, I'm well aware of the process. Thanks.KnifusMaximus wrote: ↑Sat Sep 25, 2021 9:15 am
Re: Polished FRN?
To the best of my knowledge, I believe that the Ramco/Laguiole handles are injection molded ABS (Acrylonitrile Butadiene Styrene). They do not appear to be buffed but reflect the mirror polished mold they came from. As most of the handles have shrunken far more than typical Micarta (exposing the brass lines edges) on the examples that I have seen, sold, or that are in our collection, ABS or a similar plastic seems to be what they are made of. I cannot see any layers or laminate texture that would indicate Micarta (linen or paper) is the handle material.yablanowitz wrote: ↑Fri Sep 24, 2021 8:54 amIt looks like Micarta, but I don't think that Micarta can be injection molded. Sal did say that the molds for the Laguoile were destroyed when the maker went under, so there was no way to do a Sprint Run.Doc Dan wrote: ↑Fri Sep 24, 2021 8:08 amSpydiewiki says it is micarta. Does Spydiewiki have the wrong information? That is always possible.yablanowitz wrote: ↑Fri Sep 24, 2021 6:39 amI seem to recall Sal once mentioning the handle on the Ramco/Laguiole being FRN (the only way they could get the desired shape was by injection molding) which would seem to answer the question.
I could be off-base, I'm going off my memories of several posts in different threads scattered over a number of years.
It would be rather difficult to buff FRN due to the fiberglass content.
Re: Polished FRN?
It genuinely appears as though you do not have a true understanding of the injection molding process involved. Had you shown the ability to communicate like an adult, I would attempt to continue this discussion but it's obvious that you just feel like arguing about this like a child.KnifusMaximus wrote: ↑Mon Sep 27, 2021 10:37 amNah, It's not difficult at all. I get it that you want to pretend that spyderco knives are some super complicated thing to make, but in reality, it's just a blade, a few screws, and some plastic. There is nothing technologically advanced, and nothing any toy company can't produce...Bill1170 wrote: ↑Mon Sep 27, 2021 5:03 amCylinders in neat rows arising from a flat plain are rather different from the continuous angled wedges arranged in arcs on a bidirectional texture. This is especially so with regard to polishing the molds. The handle texture is far more complicated.KnifusMaximus wrote: ↑Mon Sep 27, 2021 12:20 amMushroom wrote: ↑Sat Sep 25, 2021 10:16 amYeah, I'm well aware of the process. Thanks.
-Nick
Re: Polished FRN?
Mushroom wrote: ↑Mon Sep 27, 2021 11:14 amIt genuinely appears as though you do not have a true understanding of the injection molding process involved. Had you shown the ability to communicate like an adult, I would attempt to continue this discussion but it's obvious that you just feel like arguing about this like a child.KnifusMaximus wrote: ↑Mon Sep 27, 2021 10:37 amNah, It's not difficult at all. I get it that you want to pretend that spyderco knives are some super complicated thing to make, but in reality, it's just a blade, a few screws, and some plastic. There is nothing technologically advanced, and nothing any toy company can't produce...
I used to work at a fabrication company using injection molds on a daily basis. I made prototype parts and molds for those parts. I know more about injection molds than anyone in this forum.
Have a nice day, kiddo.
Re: Polished FRN?
I would agree on the Ramco handle material. Magnified examination shows no hint of laminated material typically seen in Micarta. FRN is only one of the possible materials.N. Brian Huegel wrote: ↑Mon Sep 27, 2021 11:05 amTo the best of my knowledge, I believe that the Ramco/Laguiole handles are injection molded ABS (Acrylonitrile Butadiene Styrene). They do not appear to be buffed but reflect the mirror polished mold they came from. As most of the handles have shrunken far more than typical Micarta (exposing the brass lines edges) on the examples that I have seen, sold, or that are in our collection, ABS or a similar plastic seems to be what they are made of. I cannot see any layers or laminate texture that would indicate Micarta (linen or paper) is the handle material.yablanowitz wrote: ↑Fri Sep 24, 2021 8:54 amIt looks like Micarta, but I don't think that Micarta can be injection molded. Sal did say that the molds for the Laguoile were destroyed when the maker went under, so there was no way to do a Sprint Run.Doc Dan wrote: ↑Fri Sep 24, 2021 8:08 amSpydiewiki says it is micarta. Does Spydiewiki have the wrong information? That is always possible.yablanowitz wrote: ↑Fri Sep 24, 2021 6:39 amI seem to recall Sal once mentioning the handle on the Ramco/Laguiole being FRN (the only way they could get the desired shape was by injection molding) which would seem to answer the question.
Re: Polished FRN?
The edges of the Para 3 are "glassy" feeling frn compared to the "gritty" feeling frn from Seki, so polishing seems very possible. But I think it would also depend on the specific formula and ratio of nylon and fiberglass. I'm assuming fiberglass is much harder than nylon and is somewhat harder than the surrounding nylon. It would probably be more difficult to buff a composite where the components have very different properties.
Re: Polished FRN?
KnifusMaximus wrote: ↑Mon Sep 27, 2021 1:08 pmI used to work at a fabrication company using injection molds on a daily basis. I made prototype parts and molds for those parts. I know more about injection molds than anyone in this forum.
OK, now that you’ve said that I’ll believe everything you say
Maybe if you treated people with respect and demonstrated your knowledge without trying to put others down you’d get a warmer reception. Instead you’ve chosen to act like a troll.
I’ll suggest you review the following post by Sal Glesser, the forum’s authority on injection molding:
viewtopic.php?f=2&t=28093
Clean up your attitude or take it elsewhere.
Re: Polished FRN?
Maybe you should stop stubbornly pretending like everything spyderco does is the most technologically advanced thing on the planet.Woodpuppy wrote: ↑Wed Sep 29, 2021 5:17 amKnifusMaximus wrote: ↑Mon Sep 27, 2021 1:08 pmI used to work at a fabrication company using injection molds on a daily basis. I made prototype parts and molds for those parts. I know more about injection molds than anyone in this forum.
