Well, this randomly arrived today. I guess I will gladly eat lots of crow, LOL!
It's a well put together knife. I really have no complaints now that it's here, other than the stubby blade profile...
Here are lots of pictures, this literally just arrived in the last hour so I haven't really messed with it other than opening and closing a dozen times and taking pictures. It is a little gritty and will be taken apart and cleaned later.
Edit to add: I just noticed there is a typo on the box saying S30V, maybe that was an original intent, like the UKPK? IDK
Edit 2: I took it apart, cleaned it, wet sanded the scales with 320 grit sandpaper (extra where pocket clip rests), lubed and reassembled. No pictures because it doesn't really look different, but it was dirty and there was no thread lock used anywhere from the factory. The pivot has to have thread locker to hit the very fine point between zero blade play and easy slip joint action. It is now much better than it was as received, and it took probably 25 minutes to clean, sand, reassemble and put everything away.
