Q-Ball
- Josh Crutchley
Q-Ball
The Dodo has more room around the lock cutout so the larger chamfer doesn't interfere with anything. The Q-ball has the cutout very close to the edge of the scale and just as close to a screw. The larger chamfer isn't possible using the Q-balls current design. The Dodo is on top this time.
There's one more knife with a cage-less Bbl and that's the D'Allara. I can only guess by looking at pictures but it looks like it also has the cutout close to the edge. It looks like the scales are thinner and there's a depression in front of the cutout possibly serving the same purpose as the chamfer. I'm trying to figure out how to modify it without making any part of the scales to thin. I would like to get rid of some excess weight by ditching the liners and trimming down the back spacer/lock bar. In this picture you can see how the back spacer is one solid piece of steel. No matter what I choose to do this knife is definitely a keeper!
- VooDooChild
Re: Q-Ball
Im pretty sure the D'Allara 3 is the same as the q-ball with the exception of the plunger.
Anyways it got easier to disengage once the spring broke in.
With that said its still not great. Not sure I could one hand unlock it with slippery hands.
Re: Q-Ball
The plunger is shorter and plastic and the ball is bigger on the D'Allara 3 when comparing it to the Q Ball. The ball actually looks like it's about even with the outside edges of the scales on the D'Allara 3. It sits slightly into the scales on the Q Ball. The scales are also slightly more chamfered around the lock cutout on the Q Ball. Looking at them side by side, I'm not sure there's much that can be easily done to give better access to the lock on the Q Ball. It would almost need thinner liners or to somehow be made linerless. But that would require some serious engineering.
- araneae
Re: Q-Ball
I've got issues with the naked ball lock. Never found it easy to use. CBBL is vastly superior in my opinion.
-Nick
Last in: N5 Magnacut
-Nick
Re: Q-Ball
I never had a problem with the ball bearing lock until the Q-ball. Absolutely the worst lock stick I have ever encountered on a knife.
Re: Q-Ball
I don’t have a Q-Ball, but I do have a D’Allara3.
Disengaging its lock is a piece of work, no doubt.
My problem is not overcoming lock-stick but getting purchase. I’m getting better at it, because it’s so worth the effort.
Re: Q-Ball
The QBall is really great ergonomically and I like the stubby, functional Wharncliffe blade a lot. The lock though.. for a knife that could so easily excel as a work/utility knife, adding one of the more difficult locks to disengage never made much sense to me. I just couldn't warm up to the QBall, didn't end up carrying it very often, and eventually, it became one of the very few Spydies that I ever sold. Not a bad knife, just not for me..
Rick H.
Re: Q-Ball
Q-Ball 2, should it ever be made, would make a great knife with a caged ball bearing lock.DSH007 wrote: ↑Fri Jun 18, 2021 10:38 amThe QBall is really great ergonomically and I like the stubby, functional Wharncliffe blade a lot. The lock though.. for a knife that could so easily excel as a work/utility knife, adding one of the more difficult locks to disengage never made much sense to me. I just couldn't warm up to the QBall, didn't end up carrying it very often, and eventually, it became one of the very few Spydies that I ever sold. Not a bad knife, just not for me..
Re: Q-Ball
I think that would be a game changer for the model.. great idea!JRinFL wrote: ↑Fri Jun 18, 2021 10:54 amQ-Ball 2, should it ever be made, would make a great knife with a caged ball bearing lock.DSH007 wrote: ↑Fri Jun 18, 2021 10:38 amThe QBall is really great ergonomically and I like the stubby, functional Wharncliffe blade a lot. The lock though.. for a knife that could so easily excel as a work/utility knife, adding one of the more difficult locks to disengage never made much sense to me. I just couldn't warm up to the QBall, didn't end up carrying it very often, and eventually, it became one of the very few Spydies that I ever sold. Not a bad knife, just not for me..
Rick H.
Re: Q-Ball
I have a Q-Ball and the D'Allara 3, and the Q's always been easier to unlock for me on my examples. A Manix 2 cage doesn't look as nice, but is a lot easier to manipulate than either.
- Josh Crutchley
Re: Q-Ball
I'm surprised the Q-ball is the newest design and they made it harder to open. I agree a caged version would be nice upgrade along with some tool steel.
Re: Q-Ball
I've always wondered if changing the spring on a Q-Ball (like the Manix 2) would make it more easier to open?
I've always wanted to try one and was especially tempted when one of the stores from Amazon offered this for a good price, but I've always been wary of the stiff lock.
- Josh Crutchley
Re: Q-Ball
I'll try it and let you know.nerdlock wrote: ↑Fri Jun 18, 2021 7:04 pmI've always wondered if changing the spring on a Q-Ball (like the Manix 2) would make it more easier to open?
Edit: The problem still seems to be getting grip even with a weaker spring.
Re: Q-Ball
The spring on mine is fine, but just like Josh I have trouble gripping the little low friction ceramic ball. A machined rod would work as well, but it might look to close to a Benchmade. It would also cost more to produce.
Re: Q-Ball
Joshcrutchley1 wrote: ↑Fri Jun 18, 2021 7:11 pmI'll try it and let you know.nerdlock wrote: ↑Fri Jun 18, 2021 7:04 pmI've always wondered if changing the spring on a Q-Ball (like the Manix 2) would make it more easier to open?
Thank you for the confirmation. I guess this is more of a design issue that cannot be resolved with just a simple parts replacement.
- Josh Crutchley
- PeaceInOurTime
Re: Q-Ball
The Q Ball is basically the wharncliffe Native I've hoped for, but to echo what has already been said, the lock is more difficult to operate than it should be.
This was my attempt to make it easier to operate: a piece of paracord through the lock in front of the ball with a knot on each side. It's much easier to use, but you have to be mindful of how you're pulling on the cord as it could slip down and hinder the lockup.
It's a great design with a difficult lock, IMO. A CBBL would have been perfect.
- Josh Crutchley
Re: Q-Ball
Well here's the first attempt, it works good but I want it to be more oval than round. I'm in the process of printing an oval one.
Re: Q-Ball
Instead of clipping spring loops, use longer thinner gauge spring wire. At least that's what we do when lightening triggers on comp guns. Smoother pull and safer.
- Josh Crutchley
Re: Q-Ball
I've already tested a lighter spring and it didn't help. It's the fact it uses a smooth ceramic ball. I just made a cage for it that seems to work a lot better than without one.
