What Will Be The First Magnacut Model?
Re: What Will Be The First Magnacut Model?
$6000! <cough> My truck isn't worth $6000 even after the transmission rebuild.
Seems like the "new steel" launches are mostly coming out in the Para3LW, N5LW and M2LW.
I'll be happy if it's any model I would plausibly EDC that isn't over $150.
...though a G10 Manix, PM2/Para3, N5 or UKPK would undoubtedly convince me to pay a bit more... I already have too many Millies, but that would also be hard to pass up!
-David
A large run of Mules, a Military, and a Manix (either LW or G10) would be my choices.
Want: SPY27, K490, Swick 5.
There are several mules that are still made in the US. I know for sure my SPY27 mule was. I think the most obvious choice would be for the mule to be first before any production models. I do think the first folder will be a Golden, CO model.
Para 3 Maxamet | Para 3 CruWear DLC | Smock M4 Jade G-10 | Shaman Z-Wear Micarta | Salt 2 LC200N Wharnie | Chaparral Birdseye Maple | Lil’ Native S90V CF | Dragonfly 2 20CV | Ladybug K390 | CRK Small Sebenza 31 S45VN PJ
Ughhhh. For real, that's as much as a nice PRS rig or a used car with a lot of life in it, or a months rent in San Fran
Certainly the hype machine is turned up to 11 on this one. MagnaCut looks like it's going to be a nice balanced steel for a lot of knives, but it's not magic. Per Larrin's charts, at it's hardest, MagnaCut barely bumps up into the bottom end CATRA range for S30V while maintaining nominal S35VN toughness. Run soft, toughness increases but the CATRA score is below S35VN.
This is obviously not a bad spot on the chart to sit, and it's going be a great standard option, but we're not talking lightsaber performance to back up those lightsaber prices.
https://youtu.be/blpWea5lElU
https://youtu.be/Q_mEJtgGVZE
https://youtu.be/URnTuXNzs0o
https://youtu.be/y9WHNA_4FMY
https://youtu.be/YCsQMafTjDQ
Thanks to BBB for making these!
Almost as good as being there.
Mule Team Army 001
MNOSD 008
MNOSD 008
- kennethsime
:D :D :D
We laugh, but that $3,000 knife will be on the bay the very same day it launches for $6k.
Stretch 2 or native 5
I doubt we will see much magna in the general public release, heck I would like some spy27 knives and that seems difficult
“”Think of an edge as a living thing that comes and goes, born, get's old, is reborn.””
SAL :spyder:
“ The best laid schemes o’ Mice an’ Men”
SAL :spyder:
Good to know! Thanks.
It makes me more certain it will be US Mule, followed by US folder(s).
Agreed.Gtscotty wrote: ↑Mon Jun 14, 2021 10:28 amUghhhh. For real, that's as much as a nice PRS rig or a used car with a lot of life in it, or a months rent in San Fran
I feel that Larrin designed it to be a ubiquitous stainless steel for cutlery and not some over-priced, over-hyped, boutique steel.
Spy27 is another one I'm waiting for a SE option in. There are certainly a lot of irons in the fire (pun intended).
If you look at the chart you'll see that it is much easier to get more wear resistance by moving to another steel than by increasing hardness. So I wouldn't necessarily do a comparison like 65 Rc MagnaCut vs 61 Rc S35VN/S30V. Unless the idea of the same wear resistance but higher hardness is intriguing to you (more important than pure wear resistance in many circumstances). In general I am not in favor of comparing steels only by slicing edge retention. It is too big of a focus among knife enthusiasts these days. We can make a steel with a higher wear resistance, that isn't difficult. Tougher, finer microstructure steels that are also stainless is where the challenge has not been achieved in the past. Many steel "charts" online are just ranking steels by wear resistance and it is not a good way of doing it, in my opinion.Gtscotty wrote: ↑Mon Jun 14, 2021 10:28 amCertainly the hype machine is turned up to 11 on this one. MagnaCut looks like it's going to be a nice balanced steel for a lot of knives, but it's not magic. Per Larrin's charts, at it's hardest, MagnaCut barely bumps up into the bottom end CATRA range for S30V while maintaining nominal S35VN toughness. Run soft, toughness increases but the CATRA score is below S35VN.
Steels should be charted using a 3 axis chart. I think it would make it easier to visualize all three commonly discussed attributes, edge retention, toughness, corrosion resistance. Relying on the one attribute lists feels like it could lead us too far down the wrong path.Larrin wrote: ↑Mon Jun 14, 2021 12:08 pmIf you look at the chart you'll see that it is much easier to get more wear resistance by moving to another steel than by increasing hardness. So I wouldn't necessarily do a comparison like 65 Rc MagnaCut vs 61 Rc S35VN/S30V. Unless the idea of the same wear resistance but higher hardness is intriguing to you (more important than pure wear resistance in many circumstances). In general I am not in favor of comparing steels only by slicing edge retention. It is too big of a focus among knife enthusiasts these days. We can make a steel with a higher wear resistance, that isn't difficult. Tougher, finer microstructure steels that are also stainless is where the challenge has not been achieved in the past. Many steel "charts" online are just ranking steels by wear resistance and it is not a good way of doing it, in my opinion.Gtscotty wrote: ↑Mon Jun 14, 2021 10:28 amCertainly the hype machine is turned up to 11 on this one. MagnaCut looks like it's going to be a nice balanced steel for a lot of knives, but it's not magic. Per Larrin's charts, at it's hardest, MagnaCut barely bumps up into the bottom end CATRA range for S30V while maintaining nominal S35VN toughness. Run soft, toughness increases but the CATRA score is below S35VN.
Same wear resistance as nominal S30V + higher hardness, the toughness of S35VN and corrosion resistance of 20CV is exactly what intrigues me about MagnaCut. That's why I'm mostly interested in it in the 63-65 HRC range, that's where it looks really unique. I'm not really all that interested in lower HRC MagnaCut because honestly for what I use my small knives for S35VN is tough enough, and I haven't really had any chipping problems, so I don't see that I really need more toughness.Larrin wrote: ↑Mon Jun 14, 2021 12:08 pmIf you look at the chart you'll see that it is much easier to get more wear resistance by moving to another steel than by increasing hardness. So I wouldn't necessarily do a comparison like 65 Rc MagnaCut vs 61 Rc S35VN/S30V. Unless the idea of the same wear resistance but higher hardness is intriguing to you (more important than pure wear resistance in many circumstances). In general I am not in favor of comparing steels only by slicing edge retention. It is too big of a focus among knife enthusiasts these days. We can make a steel with a higher wear resistance, that isn't difficult. Tougher, finer microstructure steels that are also stainless is where the challenge has not been achieved in the past. Many steel "charts" online are just ranking steels by wear resistance and it is not a good way of doing it, in my opinion.Gtscotty wrote: ↑Mon Jun 14, 2021 10:28 amCertainly the hype machine is turned up to 11 on this one. MagnaCut looks like it's going to be a nice balanced steel for a lot of knives, but it's not magic. Per Larrin's charts, at it's hardest, MagnaCut barely bumps up into the bottom end CATRA range for S30V while maintaining nominal S35VN toughness. Run soft, toughness increases but the CATRA score is below S35VN.
It was not my intent to focus solely on wear resistance, that's why I tried to mention toughness at relative wear resistances. I understand that steels and heat treats are a balance of often inversely related material properties, and the balance for a given application is what matters.
If they want to blow the doors off sales then introduce the Military 2 with Magnacut.
Otherwise it will be a PM2/3 (lame).
I’ll take A dragonfly2 though.
Hey Larrin,
Thanx for chiming in. I've got a challenge for you. I've been thinking of a way to make a chart that would take the 3 factors; Corrosion resistance, Toughness and abrasion resistance and present them in some way that forms a triangle and the shape of the triangle would give you an interesting way of comparing? I think if anyone can come up with it, you can.
As far as introduction with Spyderco, I'd druther begin with a bunch of Mule Teams so we can get them out to ELU's. And Larrin, Please make sure we your optimal heat treat. It will be Eric's call on models. We did order quite a bit of steel. For me, I think a Para 2 or 3 and a Shaman.
What you’re describing sounds similar to a spider chart. BladeHQ does something similar though they include ease of sharpening for a fourth rating. I’m not a big fan of the ratings they have though. I’m trying to help them improve the ratings but it’s going slowly right now.sal wrote: ↑Mon Jun 14, 2021 4:38 pmHey Larrin,
I will of course help however I can with heat treating. Those models sound like good choices!sal wrote: ↑Mon Jun 14, 2021 4:44 pmAs far as introduction with Spyderco, I'd druther begin with a bunch of Mule Teams so we can get them out to ELU's. And Larrin, Please make sure we your optimal heat treat. It will be Eric's call on models. We did order quite a bit of steel. For me, I think a Para 2 or 3 and a Shaman.
