I was swapping blades on my K390 and VG10 Enduras last night and was wondering if everyone else encounters the same scenario. I have had the exact same thing happen on a delica swap as well.
I swapped the K390 blade into the VG10 handles using all its parts, washers included. This resulted in way off blade centering and a gap between the lock bar and blade when opened. I had this happen before but just wanted to test it out again.
So, I disassembled it again and kept the K390 blade with its hardware and swapped just the scales. This worked perfectly just like it did on the Delica.
I was curious when doing a blade swap if everyone else is actually having any luck with the first method or is their "blade swap" also a scale swap? (The VG10 Endura is old but the only difference I could see was a chamfer on the index finger swell on the liner.
End result
Blade Swap vs Scale Swap
Re: Blade Swap vs Scale Swap
You should always at least keep the blade with the lock bar. I would swap scales and scales only every time I had the chance to and leave the "skeleton" of each knife intact.
