can someone please tell me what this is?
Hey guys, I'm completely new to the knife world and especially the Spiderco world. I usually buy like a $10 knife from home depot to get the job done at work. but after the ones I buy dulling so much I went to my dad for some advice on what I should buy, instead he gave me this knife that he had, (he has quite the collection). after doing some research I believe its a "paramilitary 2" and I'm so sorry if I'm like completely wrong and I sound stupid, but my thing was it seems a little different from all the pictures and videos I see of it. it has this loop on the bottom that you can like spin it and the belt clip seems to be upside down. Ill leave a picture of it attached. again sorry if i sound dumb or anything, id just like someone to clear up what it is exactly for me id really appreciate it.
~Bdog~
~Bdog~
Re: can someone please tell me what this is?
Hey, bdogswag11:
The knife is a Para 3 with G-10 handle. The ring is an aftermarket Signet Ring (not sold by Spyderco) that allows the knife to be used like a Karambit. The advantage of such a ring is debatable.
Stay safe,
Mike
Stay safe,
Mike
Welcome aboard and that's a great start! Don't ever hesitate to ask. I'm right there with you in the Spyderco universe so it's a learning game.
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- VooDooChild
Its a knife. :D
The clip can be moved to different positions.
Yes, it is a Para 3, a really fine knife. You should thank your dad profusely. That knife ain't cheap. Are those G-10 scales gray in color? It looks like it from my monitor. If so, the steel is Maxamet. It will hold an edge a very, very long time. Turn the knife over and look at the blade near the handle and see if it says Maxamet (opposite side from the picture). He really gave you a good one!
(Oh, and by the way, you are new so you are probation. Your replies will be slow getting to us.)
Yep as others have said, its a Para 3 but the scales do not look stock, they look like they're aftermarket. The other side of the blade will say what the steel is. (For example - CPM S30V)
Spyderco Para 3 - https://www.spyderco.com/catalog/detail ... ara-3/1009
The clip is more intended for your pocket, opposed to your belt. The clip can also be repositioned to either side or either end of the knife, depending on your preference.
The signet ring on the back looks to be from a company called "Wise Men Company." More info can be found here - https://wisemencompany.com/signet-ring- ... matriarch/
It's a really nice knife, hope you enjoy it.
-Nick
It looks like a very dirty blurple, not Maxamet.
Possible. On my screen it looks gray. If it is blurple, then S110V and so much the better!
It looked gray to me as well, until I zoomed in and saw the blurple around the edges.
The scales look aftermarket. It's hard to make out the texture from the photo, but they don't exactly look like G10 to me, almost more like terotuff.
-Nick
Is it just the perspective or something wrong with the clip(-placement)?
Can't be that it covers part of the comp.lock cutout?! :confused:
And funny, I really don't like signet rings, but on the Para 3 it actually somehow makes sense to me: Not used as a ring with a finger IN it, but just as extention of the short grip area behind the choil (so with the pinky not in, but outside on the "bottom" of the ring...)
For hands my size, that ring is a virtual necessity. As you say, not to put a finger in, and not to use it like a kerambit, but just for a place to put my finger.
the knife says CPM S110V. yea I made sure I thanked him once I found out the price tag on this thing I'm almost scared to use it because I don't want to break it. :)Doc Dan wrote: ↑Thu Apr 29, 2021 8:19 amYes, it is a Para 3, a really fine knife. You should thank your dad profusely. That knife ain't cheap. Are those G-10 scales gray in color? It looks like it from my monitor. If so, the steel is Maxamet. It will hold an edge a very, very long time. Turn the knife over and look at the blade near the handle and see if it says Maxamet (opposite side from the picture). He really gave you a good one!
thank you all very much for the info. had no idea so many people would help me out I really appreciate it. ill take good care of it, and again you guys are awesome you helped a ton
No worries, I run into the same issue with my photo uploads as well.Bdogswag11 wrote: ↑Thu Apr 29, 2021 3:33 pmsorry for the bad quality I had to post a lower resolution image because when i went to post the original the file was to large. sorry
- The Mastiff
Bdogswag11, welcome to the forum. That steel is a very high carbide stainless steel. It has good corrosion resistance, very good abrasive wear resistance and a bit lower than good toughness because of the high amount of carbides. That stuff will cut and cut and keep on cutting even when it feels dull to the touch because of the mini sawtooth effect of the carbides at microscope sizes. Overall a very high performing stainless steel.
I'd recommend not scraping, using as a screwdriver or other such things that you might consider with a cheap gas station knife. I'd also recommend not going thinner and lower at the edge than the way it comes from Spyderco at least until you have a chance to get to know the steel. If needed you can go up to 40 degrees inclusive from the 30 degrees it came with or you can microbevel the edge for a similar result. The point being you can tune the edge for your needs.
The knife was made for high performance cutting and slicing so go ahead and use the heck out of it. Outside of Spyderco you will likely not see much of S110V. It's so wear resistant not many companies want to make knives out of it or do the things needed to really get what the steel is capable out of it.
Joe
Joe
Bdogswag11, to add to what The Mastiff just said, I believe it is better to occasionally touch up the edge rather than let it get dull. It holds an edge for a very, very, very long time (which is what you needed) but that also means it is very wear resistant or difficult to sharpen once dull. Don't baby it. Use it. It will take it. You can cut stuff forever.
I thought so, too. All of mine are roughly centered down the middle of the scale. I didn't know you could adjust it that close to the comp lock. Maybe it's been used hard and the holes in the clip are worn?
