Right on with the PM2/Manix2 blade length and handle comparisons. I remember when the Endela came out I read the specs and said to myself “ok, it’s basically PM2 sized with Seki ergonomics and a back lock. Sounds cool.”Wartstein wrote: ↑Sun Apr 25, 2021 9:06 amJared wrote: ↑Sat Apr 24, 2021 5:22 pm....
It’s just so close in size to the Endura that I usually just end up using an Endura. It doesn’t carry enough smaller for me to tell any difference in the pocket.
I kinda think it’s main advantage, at least in plain edge format, is it’s probably legal in places where an Endura wouldn’t be. However, if you’re legal for an Endura, I’d say maybe just go ahead and get the Endura.
That´s what I meant in my post too.. For me the Endela is not right in the middle between Endura and Delica, but about 90 % Endura, 10 % Delica. Not a bad thing at all, but as you said: The Endura is close enough to the Endela that one could really consider both and decide which blade length they prefer. Endura with a long edge, Endela though in the very popular pm2-ish, manix-ish handle / blade length range (though slimmer in carry than both)
Perhaps it would have been a good option to make the Endela handle a bit shorter than it is (there is quite a bit "dead space" left in the handle, cause the blade does not fill it to the end) to distinguish it more from the Endura and give it an even more compact carry.
Though as said: The Endela handle is a tad wider than the Enduras, and the ""points" between the finger guards clearly less pronounced. So this could be a factor for some too.
And, not relevant practically speaking at all: The Endela has the most harmonic looks of the three...
The one thing I´d have liked to get transferred from the Delica and not the Endura to the Endela: 2.5mm bladestock. Though the 3mm Endela blade is still very slicey.
And it is cool. It’s actually a great design. If I lived somewhere where blade length had to be 3.5” or less and the Endura was verboten, I’d probably rock an Endela and carry on. As it is, I’m legal for the Endura and there’s a lot more Endura options out there (though the Endela is catching up fast).
Anyway, I know we’re mostly agreeing on the whole of the matter. I’m certainly not down on the Endela, I’m just a bit higher on the Endura, which is probably where you’re at too I think. I would have liked it if they’d given the Endela a bit more of a compact carry too, I think. Something to differentiate it more from the Endura model.
