Best steels to avoid fingerprints?
I'm looking for some suggestions on blade steels that don't grab fingerprints. I've noticed ZDP-189 and LC200N both show fingerprints like crazy whereas VG-10, H1, and S-30V don't. In your experience which steels minimize the appearance of fingerprints on the blade after touching them with clean hands?
Thanks.
Tsinga
Thanks.
Tsinga
Re: Best steels to avoid fingerprints?
The finish is more important than the steel.
I have to ask, why are you so worried about fingerprints? As you use, carry, and sharpen your knives, they're going to pick up all kinds of marks.
If it's that big of a deal to you, your best bet might be to pick up a microfiber cloth so you can wipe them down after handling.
Chris
Just say NO to lined FRN
Because, you know, cops, CSI and stuff :DStuntZombie wrote: ↑Thu Mar 25, 2021 3:41 pmI have to ask, why are you so worried about fingerprints? [...]
I just prefer my knives to not act as magnets for fingerprints and am looking for some advice on blade steels and or finishes to minimize their appearance. I have only found 3 steels that satisfy me in this regard (VG-10, S30V, and H1). I'd like to broaden my horizons a little with some different steels but find ZDP-189 and LC200N just don't do it for me. In the Dragonfly lineup I find the fingerprinting on ZDP-189 is far greater than that of VG-10 and H1.StuntZombie wrote: ↑Thu Mar 25, 2021 3:41 pmI have to ask, why are you so worried about fingerprints? As you use, carry, and sharpen your knives, they're going to pick up all kinds of marks.
Oh and most of my knives are not carried, used, or sharpened for some crazy reason.
StuntZombie has your problem solved. Microfiber cloth and a wipe down. If it is good enough for NickShabazz, it's good enough for me. Dude cleans it all and cleans it well, with microfiber.
Ah. So you're mostly just pulling them out from somewhere, fiddling with them and putting them back?
Maxamet might be a good option, since it has more of a subdued rather than polished finish. But, if you're not using it, I'm not sure the price premium would be worth it.
I think most of the CPM steels tend to have a satin finish that does well hiding fingerprints. Or, since you're not using them, you could just stick to the steels you prefer. You'll have a lot of different models to choose from.
Chris
Absolutely correct. I pull them out, fiddle awhile, and then put them back. I also have a habit of selling them and then buying the same models over again :D . I just want to try something different and it irks me to see the fingerprints.StuntZombie wrote: ↑Thu Mar 25, 2021 4:21 pmAh. So you're mostly just pulling them out from somewhere, fiddling with them and putting them back?
Wear cotton gloves while fondling the knives?
Get coated blades
Stunt Zombie’s right. It’s probably the least important reason to choose Maxamet, but Spyderco stonewashes the blades so they have more of a matte finish. If you like to fidget the Manix 2 might be worth considering.
Practically speaking a microfiber cloth would be much more economical.
Any highly polished steel is gonna show fingerprints. Stonewashed blades don't show the fingerprints nearly as much.TSINGA wrote: ↑Thu Mar 25, 2021 4:06 pmI just prefer my knives to not act as magnets for fingerprints and am looking for some advice on blade steels and or finishes to minimize their appearance. I have only found 3 steels that satisfy me in this regard (VG-10, S30V, and H1). I'd like to broaden my horizons a little with some different steels but find ZDP-189 and LC200N just don't do it for me. In the Dragonfly lineup I find the fingerprinting on ZDP-189 is far greater than that of VG-10 and H1.StuntZombie wrote: ↑Thu Mar 25, 2021 3:41 pmI have to ask, why are you so worried about fingerprints? As you use, carry, and sharpen your knives, they're going to pick up all kinds of marks.
- Julia
- The Mastiff
People here always have good answers. I'll add that waxing the blade with paste wax keeps the oils and salt from getting in the pores and beginning corrosion. Some oils I've seen used on knives really show fingerprints even though they are preventing corrosion. If it's just aesthetics you are thinking of then coarser finishes , coatings or wax. Wax seems to clean the steel up and make it very pretty. It shines it up while cleaning and stopping corrosion. It will look best on high quality finishes while on stone wash finishes it really helps seal the pores to keep it corrosion free. To me stone wash finishes mean more care to keep rust spots away.
Thank you to everyone who responded this evening.
Alvin Karpis hired a mob physician to cut away the epidermis on his fingertips, burn the prints away with hydrochloric acid, and scrape off whatever ridges remained. If your fingerprint dilemma doesn't require such drastic measures, perhaps you could benefit from knife wax. I have a bottle of Flitz, and it works reasonably well at managing metal surfaces. Even car wax should work, if that's what you have available. I think these latter options are your best bet, as Alvin Karpis' fingerprints eventually grew back.
- steelcity16
Just keep a microfiber cloth and 99.9% rubbing alcohol nearby.
- chuck_roxas45
- araneae
Try plastic cutlery?
-Nick
Last in: N5 Magnacut
-Nick
Please tell me you don't envy that clown Shabazz?? :confused:ykspydiefan wrote: ↑Thu Mar 25, 2021 4:19 pmStuntZombie has your problem solved. Microfiber cloth and a wipe down. If it is good enough for NickShabazz, it's good enough for me. Dude cleans it all and cleans it well, with microfiber.
This question is definitely one of the oddest I've seen in awhile!
15 's in 10 different steels
I just use my sweat pants to wipe off my Manix 2 LW after I'm done fidgeting. Man I love this knife.
