I took apart my Pheonix
I went ahead and took down my Pheonix mostly for fun. Thought some folks would appreciate to see the inside of the knife.
Re: I took apart my Pheonix
Really cool to see the inner workings, thanks for sharing. I would surely lose parts of the lock if I attempted this.
My Phoenix has some bad lock stick. I used a jeweler's loupe to look at the where the lock engages and the tang (without disassembling). Where the lock engages looks rather rough as compared to the rest of the tang. Did you notice anything similar? Also, thanks for the photos. I was curious myself, but am hesitant to take it apart.
Thanks for sharing, I'm always interested in the mechanics of a device.
Teflon washers, or whatever benchmade used in their mini afck, are fine with me. I beat on that knife every day for 15 years and the washers are still fine, no blade play and still smooth as new.
jpm2 wrote: ↑Thu Mar 11, 2021 6:30 pmThanks for sharing, I'm always interested in the mechanics of a device.
This is the first knife I've owned with teflon washers. Honestly, I don't see what the big deal is regarding PB vs teflon. The action is nice and smooth. I don't feel like this is a downgrade or that teflon is holding back this model.
Yes, mine has lock stick too and that’s part of the reason I took the knife apart. The area that the ball engages was pretty smooth but I went over it with some fine steel wool just to see if that would help. Unfortunately it did not.p_atrick wrote: ↑Thu Mar 11, 2021 6:28 pmMy Phoenix has some bad lock stick. I used a jeweler's loupe to look at the where the lock engages and the tang (without disassembling). Where the lock engages looks rather rough as compared to the rest of the tang. Did you notice anything similar? Also, thanks for the photos. I was curious myself, but am hesitant to take it apart.
Why teflon washers?
I could have sworn this knife was advertised as S30V, anyway to expensive for my blood and not really interested
Exactly. I'd be too afraid I'd have to raise a thread afterwards asking for spare parts....
But cool that you did it, and shared the pics. Thanks! Interesting indeed.
Michael
Probably what the maker uses. The superhawk and superleaf had Teflon washers too.
Mine has bad lockstick as well, which is really unfortunate considering how much I like the knife otherwise. It opens so smoothly. I wonder if a shorter spring would help. The stock spring seems stronger than it needs to be.
Well, curiosity got the better of me. I took it apart and swapped the factory spring with a spring from a Pilot G-2 pen and the lockstick is gone. I'll play around with it for a while to confirm then I'll be trimming the factory spring.
Interesting. Maybe I’ll try that if the stick persists. How is the fitment of the G2 spring?
The spring is a bit too wide for the plunger head, but not enough that it'll go over it. It sits just a bit canted. Works great, though. I imagine it would last about forever, but I plan to swap the original back after modification. If it were a $5 knife I wouldn't worry about it, but this isn't exactly a $5 knife :rolleyes:
I still get a tiny bit of lockstick here and there, but I can operate the lock easily with one finger now. Before I was using two fingers and it hurt. Now it's a joy. I've been flicking it open and shut ever since I made that last post. It's pretty great.
It just needs some breaking in. I'm sure a few 100 cycles will work it out and strengthen your fingers too.
Send it over. I'll break it in for you :D
Haha, had I not done this spring mod I may well have taken you up on that offer! :cool:
I own the first run Phoenix and just took delivery on the red model early this week. I was hyped because my white Phoenix is outstanding.
I am unimpressed with fit/finish with this red one...I'm calling the seller to see if they'll take it back, if not, I will try to sell it myself. After I disclose and detail the sloppiness, I doubt I'll break even.
It's the last time I buy a $315+ Seki City model. Perhaps the last Seki City model I'll ever buy-- yes I'm THAT disappointed with the quality.
*Sharp 90 degree angles on the inside of the handle liners at various "hot spots."
*Sloppy blade/backstrap interface >>> gap.
*G10 looks more pink than red to my eye. It also has sharp edges on the front of the radius.
*Rear pommel is sharply pointed.
*annoying lockstick...the only BBL I've ever had stick.
What is truth? Pontius Pilate
