health effects of sharpening
I've been wondering this for a while - are there any doctors in here than can chime in? Are there negative health effects from knife sharpening (besides cutting yourself)? A lot of the particles that you come into contact with, especially if you're dealing with diamond sprays that can get down to the 30 nanometer range, are way below the blood-brain barrier size. These particles can infiltrate your entire body basically... do they?
Re: health effects of sharpening
Hi Kaylindris,
Welcome to our forum.
I'd like to hear opinions on this?
Like almost everything in life, I suppose it is a question of quantity and circumstances.
It is not the same to sharpen once a week or ten days for a quarter of an hour or half an hour with traditional systems (stones and leather for the stropping) than to sharpen 8 hours a day with pulverized diamond in aerosols or sprays and aggressive chemical compounds.
I am not a doctor but I think that going down the street every day breathing heavy metals produced by combustion must do more damage than breathing nanoparticles from an aerosol when sharpening once every several days or weeks.
Si vis pacem para bellum
I would think that any air borne particles that are produced from using grinders, whetstones or any other sharpening tools could have potential hazards if you are not protected. On the other hand if we only knew of all the stuff that we breathe in on a daily basis we would probably be astounded to know what our respiratory system constantly endures even on a daily basis.
The only time I ever use any type of respirators or any other type of protection is when I'm using a dry, high speed grinder of some type. The few times I do use a grinder I mostly use my TORMEK system which is a wet grinding tool which does not produce air borne particles as far as I know. And do keep in mind I'm very safety conscious in any work I do and always have been.
It's like anything else you work with you just have to use common sense. But I do commend anyone who tries to be aware of any type of hazards that they work with. We only get one body and one set of lungs. I'm sure that the habit of smoking tobacco ( or anything else people smoke for that matter) is far more destructive to lungs than occasional exposure to small particles produced while sharpening a knife or any other edged tool. With that said it is amazing what the body can endure.
If you are a professional knife sharpener who sharpens 6 hours a day its not healthy.
In former times they did not get old. Bad air, cold environment from the water turning the wheel...
If you do it as a hobby it's not that unsafe.
I have worked in shops over the years where there are a lot of air borne particles. I've also worked on jobs working with epoxy coatings and other chemical type exposures that have the potential of being brutal on one's health. But in both cases whether it was hazardous air borne particles or chemical type fumes you've just got to protect yourself.
I've always gone out of my way to use respirators or any other safety equipment where applicable. I just turned 67 this past winter and my overall health isn't bad at all and I've sharpened dozens upon dozens of knives and other edged tools. You've just got to protect yourself if your exposure is potentially bad.
I have a friend who does industrial health and safety for a living, as in director of health and safety for big contractors that do superfund site cleanup type industrial work. He's active in the knife community as well, so I'll ask him for his thoughts.
I'm certain it causes cancer in California.
Generally I don't think any of those particles should be so airborne or in such large quantities that you're breathing them. I've noticed steel dust from sharpening, and certainly more of it when doing a heavy reprofile job. I think I'm safe, there are other more serious things trying to kill me on a daily basis.
- bearfacedkiller
We come into contact with many toxins on a daily basis. It is about the quantity of exposure. I would worry less about basic carbon steels like 1095 and more about the modern high alloy steels. Knife makers wear respirators and I would guess that some of the employees at spyderco do as well. As a casual knife sharpener I am not worried at all. I don’t clean my stones off by licking them and I am sure I am being exposed to more toxins in other areas of my life than through this hobby. I have worked a bunch of blue collar jobs and I have been exposed to all sorts of stuff. As a gear head and gun guy I have been exposed to so much exhaust, welding fumes and lead that I cannot imagine that it is the knife sharpening that is gonna kill me.
Curious to hear more from others though?
I use soapy water on DMT diamond plates, on Spyderco ceramic stones, on Naniwa Chosera water stones etc etc. Water will catch particles and keep them in the slurry. Out in the field, use your saliva.. Problem (literally) solved.
I usually wet the cbn stones. Not because I’m worried bout the dust, but because it quiets the process a little which calms my nerves, putting enormous scratches in a high zoot steel. It seems to help me make a smoother stroke as well, though I’ve also learned to use lighter pressure.
Well if you say they can, then I suppose they can.kaylindris wrote: ↑Sat Feb 27, 2021 9:03 pmThese particles can infiltrate your entire body basically... do they?
I'm not one to seek out things to fret over. But if I was fixated on particulates, I might first look to what happens when I sweep the shed, dig up the garden, trim the bushes, drive down the freeway at rush hour, or cook your steak on the outdoor grill. The risk from airborne sharpening debris is infinitesimal compared to hundreds of other daily activities.
I avoid nano sized products whenever I can. Most are easily absorbed through intact skin from what I read. This is not something to mess with all for the sake of a shiny edge. Long term exposure to nano particles is still an unknown.
As to regular sharpening, is see no major risk unless you are doing power sharpening frequently. If so, where a respirator.
Added reference link: https://www.niehs.nih.gov/health/topics ... /index.cfm
I wouldn’t worry too much about it unless this is your occupation or you are heavily involved in frequent dry sharpening at home. Myself, I only think about it when working on steel with heavy metal content (e.g. n690co) and try to do it outdoors and clean up well when done. I have young children and don’t particularly want them exposed to metal dust floating in the air inside my home.
As you know, everything in California causes cancer! I live here, and you just can’t be too careful. I’m sure wood dust has done more damage to me than sharpening ever will.Evil D wrote: ↑Sun Feb 28, 2021 5:40 amI'm certain it causes cancer in California.
Sounds like the only potential issue are micron solutions. Usually with water involved and the slow speeds of hand sharpening there is not the issue of airborne particles.
I don't know physically, but for my mental well being, it's a great way to relax!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
My guess is it can be an issue with something like the worksharp, literally throwing the plume of debris strait up into your face.
But how do they keep the warning label on the sunlight there? Or is U.V. exposure the only thing that doesn't cause cancer in California?
