Wish “salt” blades came on different handle colors other than yellow or green
Any reason the h1/lc200n steels only come with yellow or green handles? Needed for visibility?
I wish they would offer the steels with normal black/blue, less bright colors for every day use. I am not a big fan of carrying knives that stand out, but love knives that are corrosion resistance.
I currently blade swapped mine, but would love the option for a less bright handle.
- Abyss_Fish
Re: Wish “salt” blades came on different handle colors other than yellow or green
rit dye
Lightly insane.
All the lightweight salts (Atlantic, Pacific, Tasman, and Salt) come in H1 with black handles. Some with TiCN blades as well.
- PaperKnife
Bingo.
That was the intention.
Check out this cool vid that shows color saturation at depth.
https://youtu.be/AAJjdA6b4Ts
The salt, Atlantic, Pacific and Tasman at least can be had with black handles and the salt and Pac salt can be had with a black blade too.
None of the newer lc200n models yet though. Unless you count the all titanium spydiechef.
Yeah, I like the bright colors on some of my Salts because I only use them for outdoor water activities where I want to be able to see and find them quickly.
But, I'm glad my Spydiechef has the Ti handles.
PaperKnife wrote: ↑Mon Feb 22, 2021 12:45 pmBingo.
well, guess i cant complain that they didnt make them all pink.
if only this worked on blades. i wish we could get blacked out versions of all salts.
C253GBBK, C258GFBL, C101GBBK2, C11GYW, C11FWNB20CV, C101GBN15V2, C101GODFDE2, C60GGY, C149G, C189, C101GBN2, MT35, C211TI, C242CF, C217GSSF, C101BN2, C85G2, C91BBK, C142G, C122GBBK, LBK, LYL3HB, C193, C28YL2, C11ZPGYD, C41YL5, C252G, C130G, PLKIT1
CPM 20CV, CPM 15V, CTS 204P, CPM CRUWEAR, CPM S30V, N690Co, M390, CPM MagnaCut, LC200N, CTS XHP, H1, 8Cr13MoV, GIN-1, CTS BD1, VG-10, VG-10/Damascus, 440C
Id be ok if they all came in black variants. Seems like they all used to come in black/satin and yellow/satin and black/DLC. Dye is fun but also semi permanent and will wear off over time.
Just buy what you want and swap them out. You might lose a buck or two on the resale but you’ll have what you want.
i wish they'd also come in coated variants of the colored handles. black and yellow or black and green would look sweet. and you could still see them under water without carrying a lure.
I think that all black lc200n models will be forthcoming. (no inside info, just a hunch)
Also, the Waterway.
Is the Autonomy 2 in the Salt line or no?
-Thomas Jefferson
-Thomas Jefferson
