That's a very capable tool for the weight. Good job!
u.w. wrote: ↑Mon Mar 01, 2021 8:29 am.....
I noticed you titled this thread (mini)-Bugout alternative.
I'm sure you are aware that the Delica and Bugout are basically exactly the same exact length when folded/carried. The Hyker is lighter though. Even comparing blade lengths of the two Bugouts I have with this Hyker - the difference in blade length is 0.125" (1/8 inch)
I know a lot of people called the Para 3 lightweight, the "bugout killer" or something like that; but the Para 3 lightweight is heavier than the Delica....
Yes, 100% in Agreement with you on all counts.Wartstein wrote: ↑Mon Mar 01, 2021 8:48 am- I mentioned both Bugout and Minibugout in the title of the thread, cause in terms of actual cutting edge the Salt 2 has practically the same anount as the MINI Bugout.. most other dimensions like the "regular" Bugout
- Yes, it always puzzled me a bit that in comparisons (even in knife center vids) the Para 3 almost always takes the role as Spydercos best fitting lightweight alternarive to the Bugout.
The Para 3 LW might be many good things, but it is not light for a LINERLESS small folder (even the similarely sized LINERED Delica is a tad lighter).
Shows again what I meant: Perhaps Spyderco could market their Salt more as a general, ultralight hiking/EDC knife for folks who want something "bugout-ish" light for whatever reason. There seem to be quite a few and seems to be a market for that.
YES!!! ALL wonderful suggestions! Anything that would make it stand out, or be super easy to spot if dropped, placed on the ground, leaves, brush, tall grass, shallow water, etc... Plus, I like some of those colors tooDoc Dan wrote: If they were going to market the Hyker version of a Salt 2 they could use other bright colors, too: Orange, hot pink, safety yellow, day glo blue, florescent red, etc. come to mind.
Wartstein wrote: ↑Sun Feb 21, 2021 7:19 pmI guess I´ll start a dedicated thread about that "marketing thing" tomorrow.
I could imagine that it would open a bit of a new market for Spyderco if they made a second version of the Salt 2 ffg in LC200N, gave it perhaps a wire clip and a different handle color (like bright blue or forest green....), just called it the "ultra-hiker" or whatever and marketed it as "their" bugout-ish superlight, "under 2 oz" folder...
The Salt, just by its name alone, might still have the image in the general market to be "only" specialized for marine environments. It also gets rarely ever recommended as Spydercos bugout alternative, but very often the Para 3 LW instead, which I personally like better than the Bugout, but which always "looses" in such comparisons (for the general market!) by its "heavier" weight...
I really like your mod. Kudos, excellent, awesome!!!
I think it's safe to say, that we are basically all on the same page. This is more or less what I've been asking for/posting about, for years now.cycleguy wrote: ↑Mon Mar 01, 2021 10:53 pmWartstein wrote: ↑Sun Feb 21, 2021 7:19 pmI guess I´ll start a dedicated thread about that "marketing thing" tomorrow.
Wartstein,
I think you and the others are very much onto something here. And, as mentioned, the obvious success of the Bugout tells us something too.
Having sat with this a few days, here is my .02:
Why not introduce a Delica 4 "Ultra Light"? I'm thinking the Ultra Light and the Salt models can co-exist. The Salt versions for corrosive environments and underwater visibility; the ultra lights for the environments where corrosion resistance and visibility isn't as important. AND, why not leverage off the amazing reputation and name of the Delica. It is the G.O.A.T. for this size EDC (ok, I'm biased but despite my bias this really is true).
Why? Well, this allows for steels that perform better in other areas. An example would be a khaki (flat dark earth or burnt bronze) FRN, Cru - Wear, Ultra Light! This could also extend to exclusives (a forest green FRN 204P Ultra Light) as well as sprints (Hap40 Ultra Light)!
Additionally, the concept could be extended to all the Seki models (not everyone is a fan of the Delica, but I won't hold that against them).
Again, just my .02,
CG
EDIT: Lightweights are nested liner FRN. Ultra Lights are linerless FRN.
Wartstein,
Again, just my .02,
CG
Users browsing this forum: aicolainen, Ankerson, bbturbodad, ladybug93, rcwill98, Spydergirl88, Superflex, VooDooChild and 30 guests
