Help me decide - Endela or stretch k390?
I was all set to buy a k390 endela and then saw the stretch 2. Now I’m split. I love the pm2, one of my favorite carries of all time. Also really like the Manix 2. I want a k390 and want a back lock and now can’t decide. Which would you choose and why?
- kennethsime
Re: Help me decide - Endela or stretch k390?
For me, it's Stretch all the way.
The key difference, to my mind, is whether you like Spyderco's "points" handle (Endura, Delica) or "swell" handle (Stretch, Native). For me, the "points" become hot-spots that stab right into my fingers in just the wrong way. On the other hand, the Stretch handle, much like the PM2 handle, feels like it was made "just for me."
The other thing is whether or not you like choils, but that's almost secondary I think.
The Endela is a slimmer knife - it will probably take up a bit less pocket space. I'd bet it's also lighter weight, and has a stronger tip.
The Stretch handle feels a lot better to me. If it were me I'd go with that.
- VooDooChild
The straight spine stretch 2 has a blade and overall size/design that is very close to the pm2. Also its handle shape isnt too different from the manix.
If you like the pm2 and manix then a straight spine stretch in k390 seems like it should be the right choice.
- kennethsime
I see your point VooDoo, but I think the handle is much more similar to the PM2 than it is the Manix (you can literally trace the "grip area" of each and they're identical). While the Manix 2 does seem somewhat similar, the addition of the "point" to create the "rear choil" makes the handle a lot less neutral than either the PM2 or the Stretch.VooDooChild wrote: ↑Tue Jan 19, 2021 9:16 pmThe straight spine stretch 2 has a blade and overall size/design that is very close to the pm2. Also its handle shape isnt too different from the manix.
To add to your other point though, and for the benefit of OP, some have called the Straight Spine Stretch the "PM2 Lightweight." I think they're pretty close to truth there.
I would personally get the stretch, the handle feels similar to the Para 2 and Para 3. The delica, endura, and endela all force my middle finger directly onto that hot spot, and the first groove doesn't have enough room for my index and middle finger together. I think this upcoming K390 stretch doesn't have metal liners like the sprint white ivory one did, which also makes it lighter.
The Stretch handle is amazing and then Sal had to go and make it even better with the Stretch 2! Stretch 2 by far!
Josh
- TenGrainBread
I prefer finger choil Spyderco's. I just like being able to spread out my index finger forward, close to the blade. I love my Endura but my Natives and Stretch 2 win out ergonomically.
IF the Stretch is not pinned, that is what I would get.
Tough choice!
- The Endela is lighter (almost as light as a Manix 2 LW), slimmer in carry, has less pronounced finger points than the Endura (and you could file them away easily anyway if you don´t like them), a stronger tip, the hand is placed closer to the edge in a "regular" grip and it is no problem at all to still choke up on the Ricasso, and, biggset plus for me: It comes in SE
- The Stretch 2 has amazing, very comfy ergos, is perhaps a tad slicier due to the wider blade, has a dedicated choil if you like that, and is MORE than just a "lightweight PM2":
Why MORE than a "lightweight PM2"?:
Handle more comfortable due to the chamfering; thinner blade stock; for me better lock; and a totally different edge-geometry: While the PM2 has a continous curve in the edge, the Stretch has a long, totally straight section, and then a pronounced belly towards the tip: Makes for a different, and imho better (a bit "wharnie-like") cutting characteristic, especially noticeable in for example whittling.
- kennethsime
I don't believe either is pinned.
buckleys wrote: ↑Tue Jan 19, 2021 9:38 pmI would personally get the stretch, the handle feels similar to the Para 2 and Para 3. The delica, endura, and endela all force my middle finger directly onto that hot spot, and the first groove doesn't have enough room for my index and middle finger together. I think this upcoming K390 stretch doesn't have metal liners like the sprint white ivory one did, which also makes it lighter.
? Of course it does still have the liners, and also the same weight...
It is not pinned.
True, but for me the Stretch is more comfortable (chamfering) and clearly a better cutter, due to the thinner blade stock and different edge (not blade-)-geometry
- bearfacedkiller
I haven’t handled an Endela yet but I have handled many many Enduras and Delicas and I cannot imagine that the Endela has better ergos than the Stretch. I vote Stretch,
- Brock O Lee
Stretch for me. The handle shape fits me perfectly, and I’ve always liked the shallow choil over the ricasso of the Endura family. Straight spine and sharp tip seals the deal.
Do you feel that the current Stretch 2 still has a shallow choil? The Stretch 1 did, but for me that changed with the "2" (deeper choil).Brock O Lee wrote: ↑Wed Jan 20, 2021 4:27 amStretch for me. The handle shape fits me perfectly, and I’ve always liked the shallow choil over the ricasso of the Endura family. Straight spine and sharp tip seals the deal.
I preferred the shallow one, gives me more control.
Stretch. If you hunt then the Stretch is a no brainer. But I'd still choose it.
Why is the Stretch so much heavier than even the Endura? Is it full steel liners, not nested or skeletonized at all?
Current Spyderco: Native 5 LW s35vn; Delica zdp; Caly 3.5 zdp/CF; Chapparel FRN cts xhp; Southard 204p; Kapara s30v; Ikuchi s30v; Spydiechef lc200n, Waterway Lc200n; Manix 2 LW 20cv
Past Spyderco: Endura zdp; Manix 2 LW s110v; Paramilitary 2 s30v
Jeeeez, all this Stretch love makes me feel like I made the wrong choice with the Endela! Though, I do find the Endela extremely comfortable and more ergonomic than the PM2 (which I'm carrying today and feels like a block compared to that Endela handle)
15 's in 10 different steels
