Lifespan of G-10?
- knife__bro69
Lifespan of G-10?
Do you guys have any experience with G10 over a long period of time? Or do you know how long this material should last with daily use? Id love to know! :D
Re: Lifespan of G-10?
Do you mean like texture getting worn? Yes, it will happend in some years, it will get smoother.
But other than that, it will not rot, or corrode, or dissolve, or shrink, or vanish....
- knife__bro69
No, corrosion of liners would not affect G10.
One thing that I just think about is when you have linerless construction with washers directly on G10. That could maybe I dug some wear, but my Chief is still in perfect condition.
If you don't throw your knife into fire, I don't think there is something that could affect life of G10
- knife__bro69
Wow thats impressivePancake wrote: ↑Tue Jan 05, 2021 2:58 amNo, corrosion of liners would not affect G10.
Top carried and used every day for 15 years.
Bottom never carried or used.
- Josh Crutchley
These are scales from my 7yr old Manix 2 when I cleaned them last month.knife__bro69 wrote: ↑Tue Jan 05, 2021 1:13 amDo you guys have any experience with G10 over a long period of time? Or do you know how long this material should last with daily use? Id love to know! :D
Before After
G10 is like death and taxes...
-Thomas Jefferson
-Thomas Jefferson
G-10 will effectively last forever. You can smooth and polish it, but unless you're taking a sander to it (which I've done quite a lot of in the past month) you're not going to wear it out. And if you like the rough texture you can rough it up with a file (or carefully with 30 grit sandpaper) again.
- bearfacedkiller
It was designed for circuit boards and is mainly intended to be both heat and chemical resistant as well as having low conductivity.
The peel ply texture will wear a little and lose some bite. It can also chip or dent if dropped. In general it is fairly abrasion resistant and fairly tough though. Other than that just don’t soak it in acetone or throw it in a fire. It will resist most lesser solvents as well as most reasonable temperatures.
With reasonable care it will outlast you.
If you get some "Ballistol" at a local hardware store or sporting goods store and give your G-10 handles periodic treatments with it your G-10 handled knives will last indefinitely. I've even seen scratches and dings heal up using that Ballistol. Now a lot of guys complain that the BALLISTOL has a bit of an offensive odor. And it does have a bit of a chemical smell to it. But if you store your knives properly that smell will dissipate pretty quickly.
When I accidentally discovered how good BALLISTOL is for G-10 handles back around 2005 I have never used anything else since. And I use BALLISTOL for a wide range of uses on firearms, fishing reels and several of my other toys. It's great stuff and there are websites and videos on it's uses. Also get the big bulk 16 ounce cans>> the aerosol spray cans cost about 7 times as much.
I just take a soft bristle toothbrush ( usually an Oral B) and gently brush the G-10 until it gets a nice smooth wet look to it. If you do it right your G-10 handles will look new and will be protected from the elements.
- knife__bro69
Thanks for all the awesome answers. It sounds like g10 is a pretty insane material!
Prolonged exposure to unfiltered sunlight can damage the epoxy resin that forms the G-10 matrix. The ultraviolet component breaks down the plastic. Pigment, especially black pigment, will greatly extend the life of G-10 exposed to UV. It limits the damage to the top surface.
- Abyss_Fish
The lifespan is yes.
Lightly insane.
It is certain? It is a sure thing? o.O
-Brian
A distinguished lurker.
It doesn’t seem to shrink at all so I think it can last indefinitely if not exposed to UV constantly. Holds up to abuse pretty well too.
knife__bro69 wrote: ↑Tue Jan 05, 2021 5:47 pmThanks for all the awesome answers. It sounds like g10 is a pretty insane material!
It is! I think G10 and FRN (which I even prefer) are pretty undestructable in any only remotely realistic scenario (and discussions on which one of the two materials is even stronger, are only of theoretical value imho).
Bill I seriously believe that a periodic treatment with Ballistol will prevent any UV damage that could occur. I've been treating all of my G-10 handled knives with it and they all look to be in great condition to this day. An old RENEGADE model I had from the early 2000s that I traded a couple of years ago looked just as new as it did the day I got it. And I attribute that to my regular treatments of Ballistol.Bill1170 wrote: ↑Tue Jan 05, 2021 6:07 pmProlonged exposure to unfiltered sunlight can damage the epoxy resin that forms the G-10 matrix. The ultraviolet component breaks down the plastic. Pigment, especially black pigment, will greatly extend the life of G-10 exposed to UV. It limits the damage to the top surface.
And I'm sure there are more products other than Ballistol that will also render UV protection for G-10 or any other materials that could be affected by UV. And typically most knife handles don't see a great deal of sunlight anyway.
An indefinite constant. :p
-Thomas Jefferson
-Thomas Jefferson
- steelcity16
I'm a little skeptical that G10 will last a lifetime. Same with FRCP and FRN, but especially FRCP. I used to do a lot of thrifting, garage sales, estate sales, etc. buying vintage items and reselling on eBay. Vintage rubbers and plastics being deteriorated was a VERY common occurrence. I get that these scale materials are not exactly plastics or rubbers, but I wouldn't doubt that they will suffer the same fate over time. There is a reason child car seats have an expiration date.
