I have been using it on mine for years now. I clean the knives off and then wax. If the surface has scratches or deep grinds I give it a second coat. The micropolishing effect makes the knives look really good and I don't seem to ever get rust with wax on it. I find it super easy to use and it takes very little time. I keep clean cloths just for the waxing. If there is grit particles trapped in the cloth it can scratch the blade. Oil on the rag or blade messes up the application. Other than that I find it as easy and fast as using that liquid silicone from A.G.Russell.The closest thing I had handy for protection was Renaissance Wax which is a little tricky to work with.
Renaissance wax dries pretty hard, and mine is somewhat dried out so once you put it on the blade it dries fast. I found that if I put it on both sides of the blade then pick up a cloth for buffing, the first wax put on was dry and hard to wipe off. On the rest of the knives I put the wax on one side at a time then buffed. I was buffing the wax off by pushing my finger against the back side of an old sock, I didn't want to do vigorous buffing near a sharp edge with my fingertip just behind a layer of cloth.The Mastiff wrote: ↑Fri Nov 27, 2020 9:24 amI have been using it on mine for years now.The closest thing I had handy for protection was Renaissance Wax which is a little tricky to work with.
Famous last words.
I have to wait for mine to dry a little before buffing it. Maybe my can is newer and not as dry?Renaissance wax dries pretty hard, and mine is somewhat dried out so once you put it on the blade it dries fast
I like BALLISTOL myself and use it for a lot of different cleaning and lubrication jobs. However when it comes to seriously cleaning any stainless blade I mostly use "Bar Keeper's Friend". BKF is a cleanser type product that you can get at most grocery and hardware stores along with big box stores like Target, Walmart ect. You can get the really tall cans at Target for right at $2. If I ever find anything that can clean and polish stainless like BFK then I start
I use BKF on sharpmaker rods and sharpening stones and many other things around the house. Never had to get that serious on cleaning a knife bladeJD Spydo wrote: ↑Sat Nov 28, 2020 4:30 pmI like BALLISTOL myself and use it for a lot of different cleaning and lubrication jobs. However when it comes to seriously cleaning any stainless blade I mostly use "Bar Keeper's Friend". BKF is a cleanser type product that you can get at most grocery and hardware stores along with big box stores like Target, Walmart ect. You can get the really tall cans at Target for right at $2. If I ever find anything that can clean and polish stainless like BFK then I start
I like the fact that it doesn't leave abrasive scratches and it removes any type of corrosion about as safely as anything I've ever used. But if any of you know of any better product I would love to try it.
Users browsing this forum: Google [Bot], Humbbaby, JonLeBlanc, R100, Wartstein and 38 guests
