Bill1170 wrote: ↑Thu Nov 19, 2020 6:57 amAs a right-handed user I was surprised to discover that the compression lock is easier to close left handed when I’m wearing gloves. Normally I use the knife in my dominant hand, depressing the lock tab with my right index finger. This proved difficult to do when doing yard work with leather gloves, and using my left thumb to depress the tab was surprisingly easy.
This is something I wasn't really thinking of thanks for mentioning it. I like different steels so I need to just get used to the RH PM2. I've already bought a second Manix 2 just a month after the first.
Please let us know if that works for you. Another thought I had is this: some users complain about the lack of traction on the compression lock tab. Would adding skateboard tape, or grooves to the tab help them? The tape is reversible so a good first step.Wartstein wrote: ↑Thu Nov 19, 2020 8:16 amBill1170 wrote: ↑Thu Nov 19, 2020 6:57 amAs a right-handed user I was surprised to discover that the compression lock is easier to close left handed when I’m wearing gloves. Normally I use the knife in my dominant hand, depressing the lock tab with my right index finger. This proved difficult to do when doing yard work with leather gloves, and using my left thumb to depress the tab was surprisingly easy.
Interesting and something I (also a righty) will have to try!
Cause one thing I don´t like too much in the comp. lock is the (for me) more difficult operation with gloves on, compared to especially liner- and backlock.
I have a left handed Paramilitary 2, and it's a very nice knife. If a compression lock was really all that great in the wrong hand, you'd see right handed people clamoring over themselves to buy up all the left-handed knives. And then Spyderco would focus production on left-handed knives, but they'd relabel them as right-handed. But that doesn't happen because it's not really all that great to operate a knife with the wrong hand.Joshcrutchley1 wrote: ↑Thu Nov 19, 2020 6:17 amHow many lefties have tried a left handed pm2? If you have is it worth it over the right handed pm2? I would think the only negative might be a reduced resale value.
All modern compression locks are 'backwards'. The Gunting had what we would now call a LH compression lock, but was intended for right-handed use, in much the same way that I use a RH PM2 in my left hand. For some reason they reversed (broke) the design, which is fine by me because it means all of the PM2 exclusives are secretly built for LH users. You just have to put the clip in the correct spot (tip up, opposite side from the lock cutout). I don't care whether Spyderco labels something as LH or RH. Superior LH single-operation closing of the PM2 is clearly demonstrated in the video I linked above.RustyIron wrote: ↑Thu Nov 19, 2020 12:44 pmI have a left handed Paramilitary 2, and it's a very nice knife. If a compression lock was really all that great in the wrong hand, you'd see right handed people clamoring over themselves to buy up all the left-handed knives. And then Spyderco would focus production on left-handed knives, but they'd relabel them as right-handed. But that doesn't happen because it's not really all that great to operate a knife with the wrong hand.
This is my opinion as well. I don't own a PM2, but I do own a Shaman and a Lil' Native with the compression lock. I fidget with my knives constantly, I have about a million ways to open and close CBBL, backlock and linerlock knives with either hand, however the Compression Lock is the only one that I actually feel unsafe closing with my left hand. It may come down to my body mechanics and I have not tried/figured out the method Accutron showed with his PM2 (I'll be trying it tonight though), but the way I see it, if using a compression lock in the "correct" hand facilitates numerous comfortable, quick and safe ways of closing the knife and using the compression lock in the "wrong" hand limits you to one or maybe two ways to operate it comfortably or safely, its in no way superior. IMHO, YMMV and all that. (Side note, this is why the CBBL is my favorite lock, because theres no such thing as a "right handed" or "left handed" Manix!)RustyIron wrote: ↑Thu Nov 19, 2020 12:44 pmIf a compression lock was really all that great in the wrong hand, you'd see right handed people clamoring over themselves to buy up all the left-handed knives. And then Spyderco would focus production on left-handed knives, but they'd relabel them as right-handed. But that doesn't happen because it's not really all that great to operate a knife with the wrong hand.
I just watched the video, pulled out my Para 3 that's set up for left pocket, tip up carry and gave it a try. (in slo-mo, of course)Accutron wrote: ↑Thu Nov 19, 2020 6:38 amI would say it's definitely *not* worth it. I find that the RH PM2 is extremely operable by lefties (and yes I'm a leftie), as long as the clip is oriented for LH tip up carry. It takes about 5 minutes to learn the technique, and it's actually a more efficient operation than closing it with your right hand, or using a LH PM2.
If you decide you like the PM2 platform, you're probably eventually going to want one in an exclusive steel or color, and those are all RH models. The LH PM2 just handicaps you.
https://www.youtube.com/watch?v=vXaIszSQQTA
Pokey wrote: ↑Fri Nov 20, 2020 8:59 amI just watched the video, pulled out my Para 3 that's set up for left pocket, tip up carry and gave it a try. (in slo-mo, of course) I've always been able to flick it open left handed, but never tried closing it left handed.Accutron wrote: ↑Thu Nov 19, 2020 6:38 amI would say it's definitely *not* worth it. I find that the RH PM2 is extremely operable by lefties (and yes I'm a leftie), as long as the clip is oriented for LH tip up carry. It takes about 5 minutes to learn the technique, and it's actually a more efficient operation than closing it with your right hand, or using a LH PM2.
My, what a resourceful bunch we have around here!![]()
Users browsing this forum: Bing [Bot], Blnd, Cl1ff, curlyhairedboy, darkjabroni, Google [Bot], JakeXman, JMM, JRinFL, RustyIron, Sharp Guy, Skywalker, steelcity16, TenGrainBread and 39 guests
