K390 will hold an edge longer and takes about the same effort to sharpen as Rex45, but when it comes to reprofiling the edge, K390 is noticeably easier.Wartstein wrote: ↑Mon Oct 19, 2020 2:54 amAlbatross wrote: ↑Sun Oct 18, 2020 1:39 pmK390 hands down. I still can't believe how easily it sharpens, considering the edge retention it provides.
If stainless is necessary, then M390/204P/20CV are the most balanced overall, but S90V takes the cake for me. It's about as stainless as S30V, but has exceptional edge retention and is surprisingly easy to sharpen. S90V sharpens more like a non-stainless steel, and with a high degree of sharpness.
Since I know you also have REX45 knives (question also to all others who own both REX45 and K390)
- How does K390 compare to REX45 concerning both edge holding and "sharpenability" ?
I never tried K390, but am really impressed by REX45. In my use it seems to hold an edge longer than my HAP 40 blades (what could be expected, given that REX 45 is run a bit harder) while I have no problems to touch it up on the SM.
Is K390 even better?
I have had more chipping on my K390 blades though. Nothing severe, just small damage, but still much less than most steels. It's no slouch, that's for sure, but there is a small difference between then in this area. For me though, REX45 is just unbelievable, as far as the abuse it can take at the edge.
According to Larrin, K390 cuts as long as steels like S110V and ZDP-189.
All things being equal, there should be no difference in corrosion resistance between M4, REX45, and K390, according to Larrin's data, and a statement he made on this forum about REX45 vs M4.
REX45 takes a very fine edge, but tends to feel smooth on the 3 finger test. K390 has a more aggressive feel, due to the difference in carbides between the two. K390 acts more like a saw, or a serrated blade, which makes it phenomenal for draw cuts, but for really hard use(edge abuse) and push cuts, REX45 is the best I've had.
Honestly, a case can be made for owning both steels, but I also think that neither of the two leaves the user wanting more.
