S30V DLC Corrosion?
cletusvandamme
S30V DLC Corrosion?
Postby cletusvandamme » Thu Oct 15, 2020 8:48 am
I recently purchased a blacked out yojimbo 2 on the secondary market that came like this.
Has anyone had any success with polishing something like this away?
:spyder:: PM 2, Manix 2, Dragonfly 2, Bradley 2, Yojimbo 2, P'kal, Caribbean, Kapara, Province
prndltech
Re: S30V DLC Corrosion?
Postby prndltech » Thu Oct 15, 2020 9:03 am
It doesn’t wipe right off with some oil? DLC coating is absorbent. Try a heavy coat of some oil/lubricant and see what happens. You’ll notice it soaks it up.
- Shannon
cletusvandamme
Postby cletusvandamme » Thu Oct 15, 2020 9:06 am
Tried soap, solvents and oil while scrubbing with a toothbrush. It doesnt come off
cletusvandamme
Postby cletusvandamme » Thu Oct 15, 2020 9:11 am
No. I have tried scrubbing it with soap, alcohol and oil and it still looks the same
Postby sal » Thu Oct 15, 2020 10:33 am
Hi Cletusvandamme,
Welcome to our forum.
Where are you?
cletusvandamme
Postby cletusvandamme » Thu Oct 15, 2020 11:57 am
Hi. Thanks Sal
Im from sweden
Fred Sanford
Postby Fred Sanford » Thu Oct 15, 2020 12:26 pm
I bet it comes off with Flitz (metal polish). There are folks here who have Flitz'd coated blades with great luck. I have never done it.
“I'm callin' you ugly. I could stick yo face in some dough and make some gorilla cookies.” - Fred Sanford
Postby sal » Thu Oct 15, 2020 12:49 pm
Hi Cletusvandamme,
I would try the Flitz metal polish and let me know if that works? Put it on and let it stand for about 15 minutes, then wipe it off.
JRinFL
Postby JRinFL » Thu Oct 15, 2020 1:37 pm
Vivi has a related post about a DLC coated blade that will be of interest to you. He had similar stains on his DLC M4 Manix XL.
https://forum.spyderco.com/viewtopic.php?f=2&t=87786
Used to be JR in CT with a much earlier join date. :rolleyes: :spyder: Native in 440v was my gateway Spyderco! :spyder: Wharnie for the whin! Friends call me Jim. As do my foes.
Postby vivi » Thu Oct 15, 2020 2:03 pm
I might have to try Sal's cleaning suggestion on it. This weekend I plan to reprofile that knife and step up my cleaning attempts.
Current carry rotation:
Pacific Salt 2 LC200N | Manix XL M4 DLC | Aqua Salt
Postby Sharp Guy » Thu Oct 15, 2020 6:55 pm
Hi Cletusvandamme,
I've used Flitz on DLC quite a lot and it works great.
jpm2
Postby jpm2 » Thu Oct 15, 2020 7:08 pm
Is it sitting on top of the coating or is it depressions? How does it feel when you run a fingernail across it?
curlyhairedboy
Postby curlyhairedboy » Fri Oct 16, 2020 3:37 am
i've seen this before on my DLC coated blades, in both s30v and 4v. It does come off with liquid Barkeeper's Friend cleaner.
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, DLC Lil Native, Sage 5 LW, 4V Shaman, Watu, Rex 45 Shaman, Rex 45 Lil Native, Caribbean Sheepsfoot CQI, Tanto PM2, Serrated Shaman
Always in Pocket: Hawkbill Dragonfly 2 H1
Fixed Blades: Proficient, Junction, Waterway
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Ouroboros, Calendar Para 3 LW, 40th Anniversary Native, Calendar Watu
Would like to own again: Currently N/A!
Wishlist: Smallfly 2, CQI SpyderEdge Caribbean Sheepsfoot, Shaman Sprints!
cletusvandamme
Postby cletusvandamme » Fri Oct 16, 2020 11:37 am
It can barely be felt. But here is another picture with different lightning and it looks like rust.
I will try the flitz polish once it gets here
jpm2
Postby jpm2 » Fri Oct 16, 2020 7:12 pm
Maybe it's just the light but it looks like a lot of pitting. There's also a lot of white specks on the blade, even in the spots that look like rust. Any idea what the white is?
I usually use fine steel wool to clean up minor corrosion.
Postby sal » Fri Oct 16, 2020 9:46 pm
Hi Cletusvondamme,
I am following the thread. From an R&D perspective, we need to know.
Postby Wartstein » Fri Oct 16, 2020 11:35 pm
Welcome to the forum and greetings up to Sweden (I am in Austria) :)
/ I´m a bit confused: In this pic the blade does not look "blacked out" and coated - ?!
cletusvandamme
Postby cletusvandamme » Mon Oct 26, 2020 8:56 pm
Hi Cletusvondamme,
Applied the flitz and this is the result
The spotting isnt as visible as before but the DLC has a slight sheen to it now. Guess i rubbed it too much
tonijedi
Postby tonijedi » Tue Oct 27, 2020 1:44 pm
On my experience, with other brands coatings, when the rust develops there is permanent damage on the coating.
Postby JD Spydo » Thu Oct 29, 2020 2:56 pm
I like your advice>> I would use the FLITZ first off and then I would also use BALLISTOL to give it a good bath with. I've had so many good results with BaLLISTOL over the years.
And if it's really stubborn you might take a soft bristle toothbrush will some "Bar Keeper's Friend" cleanser that you can get at your local grocery or hardware store. Out of those three products you should be able to remedy the problem.
Users browsing this forum: Bing [Bot], Burton Knut, Deadboxhero, legOFwhat?, Mike Blue, tonijedi and 100 guests
