Loosen the pivot a touch. It usually doesn't take much. Maybe a 1/8 of a turn, 1/4 turn max. Just don't loosen it so much you end up with blade play
That makes a lot of sense. I do like the action on the G10 (seems like a pocket shredder though), but I like the weight reduction on the LW, and it's Rex45, which is supposed to be good, not that S30V isn't good as wellTkoK83Spy wrote: ↑Tue Oct 20, 2020 8:56 pmEven with the pivot screws removed, it likely isnt dropping shut because of the pinned screws above it just behind the jimping on the blade (drawing a major brain fart as to what those are) are keeping it held tight. Over time, it will loosen up. I had a LW model once...but now have (5) G10 models, if that tells you anything on my own preferences for the Manix.
I've dismantled and scale swapped every Manix I have, I'm willing to bet it's those screws/pins that are the issue with getting it dialed in. In the G10 models, those screws sometimes effect the action more than the pivot screws if they are too tight, in my experience when putting it back together after a scale or blade/hardware swap. The LW model is just...eehhhhhh, no tinkering makes TKO a dull boy![]()
Yep, I had this issue with the s90v lightweight. And with the pinned construction you can't do much to change it. It's not ideal, imo. But I will say the action on mine improved a lot with use - I think everything loosens up and breaks in. But this is definitely one reason I prefer the g10 Manix.tomcatt1 wrote: ↑Tue Oct 20, 2020 8:37 pmI can take the pivot screws out and it still won't drop shut
If the Rex45 had screws instead of pins, I know what I'd do, I've tightened the pivot screws back up and loosened just a bit, just before blade play starts. Blew out with compressed air and oiled again. Hopefully it will loosen. The G10 is super smooth, the Rex45 takes a little flick to get started and then still sometimes doesn't seem to want to fully close without help. Seems like the ball may be keeping more pressure on the Rex one, and not on the G10, just how it seems to me .....
mad german wrote: ↑Sat Oct 03, 2020 5:20 amHi guys,
I picked up a Para 3 lightweight the other day. After getting home and really looking at the knife and playing with it a bit, I had to return it. I just can’t get into the FRN models.
Is there anyone else who feels the same? I love all my Spydies (G10 and CF scales), and really wanted to like the lightweight Para 3, but it seemed like an “imposter” of the “real deal” Para 3.
Just curious if I’m the odd man out in this train of thought.
Cheers!
MG
No, it is certainly not "inherent"tomcatt1 wrote: ↑Tue Oct 20, 2020 6:46 pmI have 2 Manix 2's, one in G10, which I just got, and the other is a Rex45 LW, I've had it for a few weeks and have used it a bit. The thing I noticed is that the G10 falls shut when the lock is released, the Rex45 one, not so much even after a few weeks of use.
Is that inherent to the different knives, or is there a suggested method for getting the Rex45 one to close more like the G10 one?
How is your REX 45 LW in that regard? As said in my post above (viewtopic.php?f=2&t=87769&start=60#p1463418) mine was butter smooth right out of the box.JuPaul wrote: ↑Tue Oct 20, 2020 9:49 pmYep, I had this issue with the s90v lightweight. And with the pinned construction you can't do much to change it. It's not ideal, imo. But I will say the action on mine improved a lot with use - I think everything loosens up and breaks in. But this is definitely one reason I prefer the g10 Manix.tomcatt1 wrote: ↑Tue Oct 20, 2020 8:37 pmI can take the pivot screws out and it still won't drop shut
My rex45 is much better. While it was stiff out of the box, after breaking it in a bit I was able to adjust the pivot and dial in very smooth action with no blade play. It seems like the majority of the lightweights are fine, but when you do get one that's off from the factory it's not easy to fix. You just have to use it a bunch and hope that it improves.Wartstein wrote: ↑Fri Oct 23, 2020 2:34 pmHow is your REX 45 LW in that regard? As said in my post above (viewtopic.php?f=2&t=87769&start=60#p1463418) mine was butter smooth right out of the box.JuPaul wrote: ↑Tue Oct 20, 2020 9:49 pmYep, I had this issue with the s90v lightweight. And with the pinned construction you can't do much to change it. It's not ideal, imo. But I will say the action on mine improved a lot with use - I think everything loosens up and breaks in. But this is definitely one reason I prefer the g10 Manix.tomcatt1 wrote: ↑Tue Oct 20, 2020 8:37 pmI can take the pivot screws out and it still won't drop shut
But actually, through yours and Ricks post here, I can see that pinned construction can be a real disadvantage indeed: So ordering a Manix LW seems to be a bit of a gamble if one really likes a knife to drop shut smoothly (since if it does not out of the box, there are less ways to adjust that than on a G10 Manix)
I see what you're saying and I tend to agree with you whole heartedlymad german wrote: ↑Sat Oct 03, 2020 5:20 amHi guys,
JD, have you ever tried out a CRK Sebenza?JD Spydo wrote: ↑Thu Oct 29, 2020 8:39 amI see what you're saying and I tend to agree with you whole heartedlymad german wrote: ↑Sat Oct 03, 2020 5:20 amHi guys,
. Now I do own and use a few Spyderco FRN folders such as the Spyderhawk, TASMAN, Endura ect. And most of them are in my "beater/user" rotation. But if I had my way about it all of those would have either G-10, Micarta, Stainless and/or Titanium handles. I like the feel of a solid tool in my hand. I've never ever had a problem with any of Spyderco's folders being too heavy....
Users browsing this forum: Bing [Bot], DukeNiemand, Google [Bot], Harlista, kobold, nerdlock, scribelr, slick228, Stuart Ackerman, ThomC and 50 guests
