Wartstein wrote: ↑Tue Sep 15, 2020 1:39 pm
Tucson Tom wrote: ↑Tue Sep 15, 2020 1:20 pm
But I am back to viewing FRN knives as "cheap knives". Pinned construction, gritty action with lock stick. Cannot recommend. Not a "gas station knife" by any means, but working its way in that direction.
Tom, I get your frustration and I am sorry for you.
But I still think you perhaps have a misconception concerning "FRN knives" (btw, the Manix LW handle is FRCP and not FRN):
- To my knowledge all FRN knives except the Manix LW actually have screw and not pinned construction!
- I have and had a lot of FRN knives: NON ever had lockstick (but two G10 comp. lock knives had)
- A linered FRN knife to me feels very solid and of high quality (Stretch, Chap for example). Actually most G10 knives to me feel "cheaper" and more "unfinished" due to the blocky, non chamfered handles...
I wish you'd give another FRN model a chance..
Stretch, Sage LW, Chap...
Thanks Wartstein. I am glad to know that most FRN knives are not pinned! I'm not going to let this knife get the best of me either.
I found some 1/8 inch aluminum scraps and epoxied a thin strip of 1500 grit silicon carbide paper onto the 1/8 edge. Then in the morning when the epoxy was set, it trimmed off the excess paper and had a nice little micro-file that I could reach in with and "lap" the edge the ball engages when the knife is locked up. So I polished that surface carefully (I just want to polish it, not remove material) and took note that it is not just one flat surface but two planes at a close angle. I look at my other Manix knives to verify this and took care not to modify this. This improved things, but there is another surface the ball runs on when the knife is locked up I can't get to. The 1500 grit was just the ticket for "polishing" that surface.
So I put some more "Brownells action lube" on the ball and am just going to carry it now and fidget with it on every idle moment and give it no rest until it is my smoothest knife. Things are coming right along.
I still intend to carry it regularly. It opens nicely, locks up tight and cuts things nicely. Why am I complaining?
The only hitch is that the ball is kind of stuck for a bit when you want to close the knife then pops loose, but I think it is getting better and ultimately I may be glad to have a knife that was made to tight tolerances.
I usually end up making a knife "mine" and getting attached to it when I fuss with it this much.
